JUSTBOOM Kit digital player DAC Raspberry Zero W PCM5121 with software
Digital audio player on network and wired source. DAC and integrated headphone amp. Headphone output and output line out 3.5.
Reference : 12773
95,00 €tax incl.
79,17 € tax excl.
Justboom DAC Zero & Raspberry Pi Zero
Compact DAC / Digital audio player
lecteur digital justboom raspbery pi zero
Raspberry Pi Zero
Tiny digital player
Based on a Raspberry Pi Zero SBC (Miniature Computer), this player features a mini-HDMI input, a micro-USB port and wifi connectivity. It is a surprisingly compact audio source that can play digital files from a hard drive, media center or streaming platform.
Despite its small size (31mm x 65mm for a weight of less than 10g) the Raspberry Pi Zero card shows performance quite suitable for audio use. There is a Broadcom BCM2835 1GHz single-core ARM11 processor, 512MB RAM
DAC Zero Justboom
The DAC Zero digital to analog converter is designed to combine ease of use and high definition sound. Versatile and complete, it connects to an amplifier, headphones or active speakers thanks to a stereo jack output and a 3.5 mm stereo line-out output
It offers a high quality digital to analog conversion capacity up to at 384kHz / 32bit and can stream high quality audio over a local area network, hard drive or directly from the cloud.
The DAC Zero has a 25mW integrated headphone amplifier
For more user comfort, the hardware and software volume can be adjusted directly by the Raspberry Pi Zero
Hat DAC Zero JustBoom
Easy to build
L'installation du lecteur DAC Zero Justboom s'effectue à la main
The assembly and installation of the various components is of elementary simplicity. No welding is needed and the components are already cut to fit by hand. If necessary, you will find a complete notice here.
First, mount the DAC Zero card (red) on the Raspberry Pi Zero using the GPIO extension. Once the cards are assembled, all that remains is to install them in the box provided.
The housing allows free access to the micro SD card slot, micro-usb (data and power), mini-HDMI input and headphone and line out outputs.
Software already installed
Justboom card micro sd
The JustBoom Player software solution is already installed on the micro-SD card provided. It is therefore not necessary to know about installing SBC software. It will be enough to insert the micro-SD card and connect the reader to the network to initialize the start-up. The device will automatically create a Wi-Fi hotspot that you can connect to in order to connect it permanently to your network. The whole (fast and easy) maneuver is detailed here .
The software is open source, that is to say it is possible to change at any time without limitation depending on your projects. In addition to Justboom (simple and complete), this player is precisely compatible with a plethora of configuration locielles like PicorePlayer (reader / media center) or DietPi (very modular).
TypeDigital player with DAC and headphone amp
DACPCM5121 Burr-Brown/Texas Instruments
Audio support384KHz / 32 bit (attention de base les pilotes Linux ne vont pas au delà de 192KHz)
Headphone ampTPA6132A2
SNR106dB
ESD ProtectionOui
RegulatorsLDOuVrms
THD-92dB
Power supplyVia micro-USB (bloc fourni) 5v 3A
Volume controlHardware compatible Alsa
ProcessorBroadcom BCM2835 Single Core
ARM512MB
InputsMicro-USB, HDMI, WIFI
OutputsHeadphone 3.5 mm, Line Out 3.5 mm
Dimensions35 x 37 x 67 m
Poids total55g
Pacakge content
boîtier plastique amp Zero
Casing
Raspberry Pi Zero
SBC Raspberry Pi Zero
Module FDA raspberry
DAC Zero card
GPIO raspberry pi zero
GPIO Header
Carte Micro SD
Micro SD Card with Justboom software installed
adaptateur carte micro SD / SD
Micro SD to SD adapter
USeful to change software
Alimentation
Power adappter for micro-USB 110-240 to 5V 3A (Raspberr Pi)
InputWiFi
InputHDMI
OutputJack 3.5mm
