ODROID-C2 SBC 2GB HDMI Ethernet 4xUSB QuadCore 1.5 GHz I2S
Reference : 11678
75,00 €tax incl.
62,50 € tax excl.
Odroid-C2
SBC 2Gb HDMI Ethernet 4xUSB QuadCore 1.5GHz I2S
Odroid-C2 vue 360°
Discover the new ODROID-C2 Hardkernel Single Board Computer, a nano computer equipped with a 64-bit QuadCore processor clocked at 1.5 GHz, and a graphic part (GPU) ARM Mali 450 with 3 cores, which allows to display the 4K without worries.
In addition, the 2GB DDR3 RAM memory provides a fast, latency-free workflow. This ODROID-C2 is the worthy successor of his little brother: the ODROID-C1 +. In addition to improved graphics, a decoding of 4K video, 2x more RAM, eMMC 5.0 support, power supply via micro USB OTG port ...
The video output is provided by an HDMI 2.0 port capable of displaying 4K at 60 frames per second, also with support for the CEC function. The network part itself is provided by a Gigabit Ethernet, plus four USB 2.0 ports are available on the map (Just like for the Raspberry Pi 3). Finally an infrared port is included on the map to control the Odroid-C2 Hardkernel on the remote control.
But what is a Single Board Computer?
A Single Board Computer is a low-cost nano-computer based ARM processor. Due to its low production cost and its plug and play aspect, an SBC is the ideal tool for teaching and any educational or personal project.
The many connection options (connectors) offer an infinite number of possibilities for HiFi, as a home automation server, audio video, multimedia, meteorological, educational, monitoring, programming in the Linux universe in particular, and others.
ProcessorAmlogic S905 SoC Cortex A53 (ARM v8), 64 bits, QuadCore 1,5GHz
GPUMali-450 PM3 GPU, 700 MHz (OpenGL ES 2.0 / 1.1)
Mémory2Go de RAM DDR3 / 912MHz
Video output / resolutionHDMI 2.0 (CEC compatible), max. 4K at 60 FPS
Video decodingH.265 at 60 FPS / H.264 at 30 FPS
Connectors4x USB 2.0
Micro USB OTG
Ethernet LAN Gigabit
HDMI
I2S Audio Interface
Jack 0.8mm
ADC10-bit SAR 2ch
Memory extensionVia Micro SD port (eMMC 5.0)
Expansion40 + 7 PIN (GPIO, UART, I2C, I2S, ADC)
Infrared receiver (IR)
Supported OSUbuntu 16.04, Android 5.1 (Lollipop)
Integrated heatsinksYes
Power supply5V 2A via Micro USB port Jack 0.8mm port
Dimensions85x56mm
Weight40g
PDF USer ManualAvailable in the "Attachments" tab of this page
schéma odroid-c2
schéma odroid-c2
block diagram odroid-c2
InputRJ45
InputGPIO
OutputHDMI
OutputUSB
OutputGPIO
