By buying this product you get 23 loyalty points
Switching Power Supply Module 1200W 2x85V
The SMPS1200 switched-mode power supply is a very high-efficiency model, capable of developing a rated power of 1200W in an extremely small footprint. It has been specifically designed and developed by Hypex to provide the 2x85V voltage required to operate the brand's UcD™ amplifier modules.
| Specifications | |
| Product types | Switching power supply |
| Input voltage range | 108-265V (on 220V main power) 90-132V (on 110V main power) |
| Voltage outputs | 2x85V DC |
| Power | Nominale : 1200W @ 20Hz Max : 1500W |
| Switching frequency | 100kHz |
| Protection | Overvoltage |
| General | |
| Dimensions | 165 x 105 x 52mm |
| Weight | 846g |
| Input | PCB Connector |
| Output | PCB Connector |
| Output voltage (V) | 85.0 |
| Output current (A) | NC |
| Input voltage (V) | 220.0 |
| Input voltage (V) | 250.0 |
| Input voltage (V) | 120.0 |
| Input voltage (V) | 110.0 |
| Input voltage (V) | 190.0 |
| Input voltage (V) | 90.0 |
| Input voltage (V) | 210.0 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 100.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 130.0 |
| Input voltage (V) | 200.0 |
| Power Supply | SMPS |
