The Mean Well SMPS LRS-450-48 switching power supply delivers 48V at 9.4A for a total power of 450W and is ideal for DIY projects. Its compact 35mm form factor makes it easy to integrate. This power supply also incorporates a number of interesting features, such as selectable input voltage via a switch, and protection against short-circuits, overloads, overvoltage and excessive temperatures.
Type of product | Switching mode power supply |
Output voltage | 48V |
Rated output current | 9.4A |
Rated output power | 450W |
Maximum electrical output noise | 360mVp-p |
Efficiency | 92% |
Protections | Short circuits, overloads, overvoltage, overheating |
Tension d'entrée | 90 ~ 132V AC / 180 ~ 264V AC by switch 255 ~ 370VDC (switch on 230VAC) |
Operating temperature | -25 ~ +70℃ |
Dimensions | 225 x 124 x 35mm |
Package | 1x MEAN WELL LRS-450-48 |
Input | Screw terminals |
Output | Screw terminals |
Output voltage (V) | 48.0 |
Output current (A) | 9.0 |
Input voltage (V) | 370.0 |
Input voltage (V) | 255 |
Input voltage (V) | 264 |
Input voltage (V) | 90.0 |
Input voltage (V) | 180.0 |
Input voltage (V) | 132 |
Power Supply | SMPS |
