MEAN WELL LRS-600-48 Switching Power Supply SMPS 600W 48V 12.5A
This is a 600W 48VDC 12.5A power supply. MEANWELL's LRS-600 series is a single-output, enclosed 600W power supply with a low 41mm profile.
Reference : 10878
79,90 €tax incl.
66,58 € tax excl.
Shipping date: 15-04-2026.
MEAN WELL LRS-600-48 Switching Power Supply SMPS 48V 12.5A 600W
This is a 600W 48VDC 12.5A power supply. MEANWELL's LRS-600 series is a single-output, enclosed 600W power supply with a low 41mm profile. Adopting a 115VAC or 230VAC input (switch selectable), the entire series provides an output voltage line of 5V, 12V, 15V, 24V, 27, 36V and 48V.
In addition to high efficiency up to 92%, with the integrated long-life fan, the LRS-600 can operate under -25~ +70℃ at full load. With extremely low no-load power consumption (less than 0.75 W), it enables the final system to easily meet global energy requirements.
The LRS-600 features comprehensive protection functions and 5G anti-vibration capability, and complies with international safety regulations such as IEC / UL 62368-1. The LRS-600 series is a cost-effective power supply solution for a wide range of industrial applications.
Product typeSMPS power supply
output48V DC 12.5A
Input range90 - 132VAC / 180 - 264VAC via switch
255 - 370VDC (swith on 230VAC)
Input frequency47-63Hz
Nominal power600W
Efficiency92%
Ripple and noise200mV
ProtectionShort circuits / overloads / overvoltages
Max. leakage current2mA
Operating temperature-20 à +65°C
Weight1kg
Dimensions225x124x41mm
Package1x MEAN WELL LRS-600-48 SMPS power supply
InputScrew terminals
OutputScrew terminals
Output voltage (V)48.0
Output voltage (V)45.0
Output voltage (V)50.0
Output voltage (V)43.0
Output voltage (V)55.0
Output voltage (V)56.0
Output current (A)NC
Input voltage (V)120.0
Input voltage (V)90.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)100.0
Input voltage (V)130.0
Input voltage (V)230.0
Input voltage (V)210.0
Input voltage (V)240.0
Input voltage (V)110.0
Power SupplySMPS
