Soldering tin - Mundorf Supreme Silver 10% (2 meters)
4.9 / 5
Reference : 3200
13,50 €tax incl.
11,25 € tax excl.
Shipping date: 18-12-2025.
Tin soldering silver 10% Mundorf
Silver solder 10% Mundorf - 11.7g
Caution : this is a partial packaging. By ordering this product you will not receive the full coil shown on the picture, but a part (2m / 11.7 of it). You can get the full coil here.
Mundorf's Supreme Msolder welding wire is composed of 10% silver. It is indicated for advanced projects that require excellent conductivity (mounting tubes, cable assembly, silver / gold foil). The silver content is balanced by a flux ratio of (2.2.3).
Caution, melting point is 290°C / 554°F, which implies the need of a good soldering iron.
Typewelding wire
Conditioning11.7g / 2m
Wire Diameter1mm
Flux2.5% 2.2.3
Melting point290 ° C / 554F
Composition
S-Sn88.60%
Cu1.80%
Ag9.50%
the0.10%
22 reviews
Alexander P.
Very good solder. Easy to work, good laying down (cohesion) with copper, better then "ordinary" 4 pct sliver content solder. Definately positive effect on sound.
This review has been posted for Soldering tin - Mundorf Supreme Silver 10% (2 meters)
Good solder
Good solder, a little bit harder to work with as it has no resin core, but only 100% solder. Recommended when you want a solder containing a substantial amount of silver.
EXCELLENTE QUALITE POUR AUDIO
Cette soudure est vraiment TOP pour faire vos cables audio.
Qualité d'écoute au rendez-vous sur vos cables.
Audible
Utiliser cette soudure est clairement "audible". Comme d'habitude Audiophonics a été impeccable dans la gestion de ma commande pourtant compliquée car plein de petits objets de montage pour connectique. Que ferait on sans eux en France ? Pourquoi ne pas leur dédier le cabinet du Ministère des mélomanes...
Helder
J'ai remplacé la soudure de mes enceintes Wilson par cette soudure Mundorf Supreme 10% Silver et le résultat est remarquable. Plus de détails, une meilleure extension des basses et un peu plus de transparence dans l'ensemble.
