Soldering tin - Mundorf Supreme Silver 10% (2 meters)
4.9 / 5
Reference : 3200
13,50 €tax incl.
11,25 € tax excl.
Shipping date: 03-04-2026.
Tin soldering silver 10% Mundorf
Silver solder 10% Mundorf - 11.7g
Caution : this is a partial packaging. By ordering this product you will not receive the full coil shown on the picture, but a part (2m / 11.7 of it). You can get the full coil here.
Mundorf's Supreme Msolder welding wire is composed of 10% silver. It is indicated for advanced projects that require excellent conductivity (mounting tubes, cable assembly, silver / gold foil). The silver content is balanced by a flux ratio of (2.2.3).
Caution, melting point is 290°C / 554°F, which implies the need of a good soldering iron.
Typewelding wire
Conditioning11.7g / 2m
Wire Diameter1mm
Flux2.5% 2.2.3
Melting point290 ° C / 554F
Composition
S-Sn88.60%
Cu1.80%
Ag9.50%
the0.10%
23 reviews
Super qualité
Bon je me suis fais des cables instru pour guitares, particulièrement sensibles aux perturbations. Dans un premier temps j'ai utilisé ma soudure, j'avais un cable identique avec connectiques identiques acheté en magasin, j'ai comparé le son c'était la Cata. Seule la soudure était différente, j'ai commandée celle-ci, certes chère mais après installation c'est top! son parfaitement identique au cable magasin à 60e... parfait merci, bon matos et arrivé hyper vite en prime ;-)
This review has been posted for Soldering tin - Mundorf Supreme Silver 10% (2 meters)
Alexander P.
Very good solder. Easy to work, good laying down (cohesion) with copper, better then "ordinary" 4 pct sliver content solder. Definately positive effect on sound.
Good solder
Good solder, a little bit harder to work with as it has no resin core, but only 100% solder. Recommended when you want a solder containing a substantial amount of silver.
EXCELLENTE QUALITE POUR AUDIO
Cette soudure est vraiment TOP pour faire vos cables audio.
Qualité d'écoute au rendez-vous sur vos cables.
Audible
Utiliser cette soudure est clairement "audible". Comme d'habitude Audiophonics a été impeccable dans la gestion de ma commande pourtant compliquée car plein de petits objets de montage pour connectique. Que ferait on sans eux en France ? Pourquoi ne pas leur dédier le cabinet du Ministère des mélomanes...
 (4)
