LITTLE BEAR MC3 XLR / RCA Converter Switch
New
The Little Bear MC3 is an XLR/RCA converter switch. It has one RCA input and two XLR inputs and outputs.
Reference : 20728
69,00 €tax incl.
57,50 € tax excl.
LITTLE BEAR MC3 Commutateur Convertisseur XLR / RCA
LITTLE BEAR MC3 picture
The Little Bear MC3 is an XLR/RCA converter switch. It has one RCA and two XLR inputs, and the same applies to its outputs. It can therefore be used as a passive switch or as a  Symmetrizer / Desymmetrizer, depending on the user's application. Input and output are selected via two potentiometers on the front panel.
The LITTLE BEAR MC3 is compatible with most audio devices, but if there is a common ground noise, please add an isolation module between the MC3 and your device.
Little Bear MC3 overview
1Input selector
2Input selector
3Output 2xXLR / 1xRCA
4Input 2xXLR / 1xRCA
Little Bear MC3 test by Audio Science Review
The MC3 is a simple device that does its job well. It's a great solution for adding inputs to an amplifier. I'm going to recommend the One Little Bear MC-3 switch.
logo ASR
Product typeConverter switch
Inputs2x Balanced stereo XLR input
1x RCA input
Outputs2x XLR balanced stereo output
1x RCA output
Dimensions150 x 105 x 68mm
Weight485g
Package1x LITTLE BEAR MC3 converter switch
InputXLR
