LITTLE BEAR MC3 XLR / RCA Converter Switch
The Little Bear MC3 is an XLR/RCA converter switch. It has one RCA and two XLR inputs, and the same applies to its outputs. It can therefore be used as a passive switch or as a  symmetrizer / desymmetrizer, depending on the user's application. Input and output are selected via two potentiometers on the front panel.
4.0 / 5
Reference : 20728
69,00 €tax incl.
57,50 € tax excl.
LITTLE BEAR MC3 Commutateur Convertisseur XLR / RCA
LITTLE BEAR MC3 picture
The Little Bear MC3 is compatible with most audio devices, but if there is a common ground noise, please add an isolation module between the MC3 and your device.
Little Bear MC3 overview
1Input selector
2Input selector
3Output 2xXLR / 1xRCA
4Input 2xXLR / 1xRCA
Little Bear MC3 test by Audio Science Review
" The MC3 is a simple device that does its job well. It's a great solution for adding inputs to an amplifier. I'm going to recommend the One Little Bear MC-3 switch. "
logo ASR
Product typeConverter switch
Inputs2x Balanced stereo XLR
1x RCA
Outputs2x XLR balanced stereo
1x RCA
Dimensions150 x 105 x 68mm
Weight485g
Package1x Little Bear MC3
InputXLR
Musical et pratique
La conversion symétrique/asymétrique fonctionne bien dans les 2 sens, ça peut éviter d'acheter des câbles adaptateurs xlr/cinch. L'appareil est transparent au niveau du son. En revanche c'est loin d’être un mini boitier, surtout en hauteur: 8cm! Les faces avant et arrière sont en plastique moulé genre ABS, de même que les socles de prises, c'est pas du Neutrik ni même du Rean mais ça ne s'entend pas, heureusement vu le prix qui ne me parait pas justifié, d’où une étoile en moins.
This review has been posted for LITTLE BEAR MC3 XLR / RCA Converter Switch
The Little Bear MC3 is an XLR/RCA converter switch. It has one RCA and two XLR inputs, and the same applies to its outputs. It can therefore be...
