Selecteur audio 1 to 2 reversible for speaker / amplifier Black L
Reference : 13231
105,00 €tax incl.
87,50 € tax excl.
Shipping date: 22-04-2026.
Audio selector
1 input / 2 outputs (reversible) to speaker
Audiophile selector switch amplifier to speaker
This device is installed directly after a power amplifier or integrated amplifier. It has two outputs and each can be connected to a (passive) speakers set .
A toggle switch on the front panel selects the active output. The function is to alternate speakers without having to redo the connections. In other words, it allows alternating speakers while benefiting from a fixed installation with permanent cable connections. It means many possibilities to test several speakers, make your versatile sound-installation ... etc.
Effective circuit with quality wires
The device's internal wirings are robust and reliable. Silver-plated OFC 2.5mm² wires ensure a clean and clear signal on input as well as output.
The ON / ON switch in charge of selecting the target speaker is an electronic component designed for high powers (10A 250VAC) tolerance.
The device is mounted on soft rubber stands to reduce vibration and scratches on the housing.
Switch speaker amplifiers
Terminal speaker audiophile grade
Quality speaker terminals
This selector has one input and two outputs, all of them are gold plated speaker terminals.
Even if this configuration needs 12 connectors, the wiring of the device has been thoroughly done to allow the device to stay small and easy to install.
Because of the many connectors and to avoid false contacts and signal loss of any kind, this speaker selector embarks qualitative terminals, fully removable, compatible with bananas plugs and easy to wire, even when using bare wire.
Reversible switch
By its construction, the audio selector can be used in both directions.
That is to say, one can use the device for connecting an amplifier to two sets of speakers used in alterance (conventional use).
However the opposite is also possible: connect two amplifiers in a single speaker system. In such a configuration, the switch will determine which of the two amplifier is active.
In one way or another, this type of device does not exempt the usual precautions when it comes to the use of an amplifier and one (or more speakers). It is imperative to put off all concerned devices before switching anything.
inverting input audio output selector
Two sizes available
Compact Audio Selector or imposing
Depending on the needs of your installation this audio selector comes in two sizes.
The larger sized one (the one we are now discussing) has larger terminals that can accept a larger contact surface in the case of using a high-precision cable.
However, the smaller version has exactly the same functions while being significantly more compact.
TypeAudio selector
Power supplyPassive
Inputs1 stereo analog inputs (speaker terminal x2)
Outputs2 stereo speaker outputs
Mode selectionLever switch
HousingAluminum
Dimensions190 x 131 x 70mm (80mm with feet)
Weight1160g
InputSpeaker terminals
OutputSpeaker terminal
6 reviews
sélecteur de qualité
Le sélecteur est de qualité, fait pour des gros câbles HP, étrier à visser. J'ai testé la résistance de chaque paire avec un ohmetre de labo, 0,2 ohm au maximum, ce qui est parfait. Pas de risque d'abîmer les amplis.
This review has been posted for Selecteur audio 1 to 2 reversible for speaker / amplifier Black L
Rapport qualité-prix TOP
Le déroulement de l'achat ainsi que l'envoi en Allemagne se sont déroulés sans problème.
Le sélecteur audio fonctionne très bien, on ne peut que le recommander.
Dommage que ce commutateur ne soit pas disponible sur le marché allemand.
Très bien
Sélecteur acquis pour utiliser 2 amplis. L’appareil est de très bonne fabrication, robuste et bien assis sur ses 4 pieds
1 ampli, 2 paires d'enceintes
Acheté pour faciliter les comparaisons entre 2 paires d'enceintes. Construit comme un tank, il fait particulièrement bien le job sans impact audible sur le son. Bref du sérieux, comme toujours chez Audiophonics
TOP
Acheté en remplacement d’un autre sélecteur de sources/ enceintes qui me jouait des tours.. celui ci est parfait.
Il remplit son rôle sans faiblir ( je l’ai testé «  à mort »)
Il semble bien robuste avec ses grosses bornes et je sens qu’on va se plaire tous les deux.
Merci à audiophonics pour le conseil.
