DAYTON AUDIO XO2W-2K 2-Way Speaker Crossover 2000Hz
The Dayton Audio 2-way crossover series was designed using a second order Linkwitz-Riley alignment (12db/octave). Dayton Audio metallized polyester film capacitors are used in the high and low pass sections. 18AWG section inductors were used to minimize DC resistance.
Reference : 15941
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 09-04-2026.
Grantie 5 ans
Dayton Audio XO2W-2K
Dayton Audio XO2W-2K Filtre Haut-Parleurs 2 Voies 2000Hz
The Dayton Audio 2-way crossover series was designed using a second order Linkwitz-Riley alignment (12db/octave). Dayton Audio metallized polyester film capacitors are used in the high and low pass sections. 18AWG section inductors were used to minimize DC resistance. A unique design feature of the low-pass section allows the use of 4 or 8Ω woofers, ideal for 2-way system design. The cutoff frequency of the high-pass filter is rated for an 8Ω load. All components are bonded or fixed to eliminate hum and vibration. The high quality blue PCB uses a backplate for rigidity and grommets for easy mounting. The power rating of this crossover is 300W.
Product type2-Way speaker crossover
Power handling300W
Crossover frequency2000Hz
Terminal width4.8mm
Dimensions16.5 x 10.8 x 3.5cm
Qualité visuelle au rdv. Reste à tester à l'écoute.
This review has been posted for DAYTON AUDIO XO2W-2K 2-Way Speaker Crossover 2000Hz
The Dayton Audio 2-way crossover series was designed using a second order Linkwitz-Riley alignment (12db/octave). Dayton Audio metallized polyester...
