TRIANGLE S02 Speaker Stands White (Pair)
Triangle has designed the S02 stands to enable you to position your speakers optimally, meaning with the tweeter 90cm above the floor, which corresponds to your ear height when seated. This will enable you to enjoy the full richness of the sound delivered by your Hi-Fi system. The top shelf of the S02 measures 16.5 x 21.5 cm and can accommodate a wide range of bookshelf speakers.
Reference : 17916
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 05-08-2025.
TRIANGLE S02
Triangle has designed the S02 stands to enable you to position your speakers optimally, meaning with the tweeter 90cm above the floor, which corresponds to your ear height when seated. This will enable you to enjoy the full richness of the sound delivered by your Hi-Fi system. The top shelf of the S02 measures 16.5 x 21.5 cm and can accommodate a wide range of bookshelf speakers, although it has been specially designed to accommodate Triangle's LN01A bookshelf speakers. What's more, it's fitted with a non-slip, scratch-resistant felt pad for added stability and protection for your speakers.
Each S02 stand comes with four height-adjustable decoupling spikes. They allow you to adjust the level of the stand to suit the slope of your floor, while absorbing vibrations generated during listening. The sturdy S02 stands are made of steel and can each support a load of up to 20kg.
Finally, the speaker cables can be hidden in the stand for discreet installation.
Product typeSpeaker stands
Height without spikes596mm
Base width230 x 270mm
Top plate width165 x 215mm
Cable passage
SpikesAdjustable
Dimensions270 x 596 x 230mm
Weight10kg
PackageSold by pair
Triangle has designed the S02 stands to enable you to position your speakers optimally, meaning with the tweeter 90cm...
