DAYTON Stereo Slide-In Stereo Attenuator with Wall Resistance 60W
This audiophile attenuator is based on a resistance switching system guaranteeing you the best possible attenuation quality.
Comes with 3 covers of different shades to fit all interiors.
Easy to install, it is compatible with the retention system
Features:/ Strong>
P>
P>
P>
P>
P>
Max cable diameter (mm) | 2.08 |
Mounting type | To screw |
Max panel thickness (mm) | N/A |
Accepts Banana Plugs | N/A |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | N/A |
