Material
Diameter (mm)
Height
mm
mm
Screw thread length (mm)
Screw thread
Screw head shape
Screw drive type (socket)
Color
Spikes and acoustic treatment
Patrick K.
Sonic Master
This cable is sooooo good that i was shocked. I did not expect this level of warm neutral detailed rich, open and airy sound...
Pierre-Marin L.
Je confirme tous les commentaires élogieux sur ce câble...
Patricio C.
Dale una oportunidad de escucha en tu sistema... y juzgalo tu mismo.
Más vale tener potencia bajo el pedal y no necesitarla que al revés.... y vaya si se nota ir sobrado de potencia. Antes usaba...
Here is our selection of tips, tailpins, absorbers, acoustic treatment for any HiFi device or piece of furniture. Indeed, the vibrations caused can be attenuated or even completely eliminated thanks to simple spikes or absorbers. Your amplifier or preamplifier will be even more efficient once equipped.
Don't underestimate the sound distror caused by the vibrations of the device or furniture, that is why we offer this wide range of absorbers and tips to remedy this.
  • Absorbers
    Absorbers
    Discover our catalog of mechanical absorbers & isolators with decoupling, magnetic absorbers, spring absorber and ball absorber. Many formats, dimensions and colors to find the part suitable for all your DIY devices & projects. Several colors and materials available, acrylic, machined aluminum...
  • Spikes
    Spikes
    Spikes are useful to limit the transmission of any vibrations liable to cause interference from one surface to another. Very effective on speaker cases. Also works all kinds of HiFi devices with massive housing. Available in several options: different threadings, materials, type of decoupling and colors.
  • Tailstocks and feet
    Tailstocks and feet
    Here is our stand catalog, available in different materials for all your repair, upgrade or improvement projects for High Fidelity audio devices. Ideal to replace a lost foot as much as to build a device with professional performance and design with vibration management and an elevation with great heat circulation.
  • Damping
    Damping
    Find our selection of shock absorbers for your audio equipment here. Pre-cut sheet of self-adhesive bitumen, foam, felt to finely control each aspect of your listening environment and temper excessive surface vibrations be it on air or solidian vibration.
  • Absorbents
    Absorbents
    Finalize your speakers, transmission lines, bass reflex cabinets with our absorbent foam dedicated to speaker damping. We have gathered this large choice of thicknesses, materials, grammage and colors for great DIY speakers.
  • Acoustic fabrics and Panels
    Boost the audio performance of your listening room / recording studio acoustic with our selection of high quality acoustic fabrics to apply a clean, reliable treatment that meets your specific constraints.
