ARYLIC UP2STREAM MINI V3 Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay
The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device. Practical, it allows you to limit the cables running through your audio system, while giving you the possibility to control the playback remotely.
Reference : 14648
39,90 €tax incl.
33,25 € tax excl.
Arylic Up2Stream Mini V3 Module Récepteur Bluetooth 5.0 WiFi DLNA UPnP AirPlay
What's new in the V3 version
In this V3 version, the Up2Stream Mini is equipped with additional features and optimizations:
  • The Up2Stream Mini V3 now supports both WiFi and Bluetooth.
  • It can connect to a computer and function as a USB DAC.
  • It is possible to change the WiFi and Bluetooth ID via the 4Stream application.
  • External extension ports have been added.
Very simple to set up, a mobile control application can be downloaded for free, to allow you to control the different Up2Stream receivers in your network in a multiroom integration.
Application 4Stream Android
Application 4Stream iOS
The application is compatible with many streaming services, such as Spotify, Deezer, Tidal, Qobuz, Amazon Music, Pandora, Napster, iHeart Radio and web radios. It will also allow you to go to the files stored on your NAS. The Up2Stream Mini V3 can also be connected to a computer to function as a USB DAC.
Arylic Up2Stream Mini V3 Module Récepteur Bluetooth 5.0 WiFi DLNA UPnP AirPlay Arylic Up2Stream Mini V3 Module Récepteur Bluetooth 5.0 WiFi DLNA UPnP AirPlay
Arylic support chart
Compatibilité des modules Arylic
Product typeWiFi / Bluetooth receiver
ConnectivityWiFi IEEE802.11 b/g/n 2.4G
Bluetooth 5.0 (SBC / AAC)
Audio outputs1x Jack 3.5mm output / 1x Connector 4 pins
1x SPDIF 7 pins output (44.1kHz)
SNR100dB @ 0dBFS, 1kHz
THD+N0.03% @ 0dBFS, 1kHz
Supported formatsFLAC, MP3, AAC, AAC+, ALAC, APE, WAV
DecodingPCM up to 24bit 192kHz
Supported streaming protocolsDLNA, UPnP, Spotify Connect, AirPlay, QPlay
NAS SupportNAS avec support DLNA
Power supply5VDC 1A on 2 pins connector
5VDC 1A via Micro USB
Dimensions55 x 45 x 12mm
Package1x Arylic Up2Stream Mini V3
1x PH2.0 4 pins cable
1x PH2.0 7 pins cable
1x 2 pins power cable
1x WiFi Antenna
InputWiFi
OutputJack 3.5mm
OutputS/PDIF
OutputPH 2.0mm
DAC / ADC ChipNC
Max sampling rate192kHz
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
3 reviews
Facile à installer, utilisé avec BubbleUpnp je peux écouter Qobuz et les radios numérique de Radio France avec mon vieil ampli des années 70.
YB
This review has been posted for ARYLIC UP2STREAM MINI V3 Bluetooth 5.0 WiFi Receiver Board DLNA UPnP AirPlay
très simple , plein de sorties possibles , numérique et analogiques.
Parfait pour sonoriser ma terrasse
J'avais un système DIY avec ampli Tripath2x100W, une paire de Kef tropicalisées avec une carte airplay (Airtry) qui fonctionnait un peu qd elle voulait. J'ai donc juste eu à connecter l'alimentation 5V sur la carte connecter les sorties analogique à l'ampli. En 45 min , configuration wifi comprise ça fonctionnait à merveille. Spotify en DLNA ou Airplay depuis le mac ça marche nickel, je recommande
The Arylic Up2Stream Mini V3 is a WiFi and Bluetooth 5.0 receiver that will allow you to easily stream your music from any connected device....
