LB Aluminum Push Button with Blue Light 220V Ø12mm Silver
1NO type switch with blue indicator light. Operates from a bistable mechanism (two positions). The connectors dedicated to the signal / power supply can support a voltage of 220V. Those dedicated to the power supply of the indicator light (LED) can accept voltages between 5 and 24V.
Reference : 17518
5,90 €tax incl.
4,92 € tax excl.
Shipping date: 03-04-2026.
Switch
1NO 220V
LB Interrupteur Aluminium avec Cercle Lumineux Bleu 5-24V Ø12mm Argent
An ideal part for your projects, DIY assembly, to repair / improve an existing device or build a control panel from scratch.
Product type1NO Bistable switch
Screw thread diameter12mm
Max panel thickness8mm
Total dimensions26.3*⌀13.8mm
LEDColor: Blue
Voltage: 5-24V
Number of pins4
Voltage220V
LED ColorBlue
Number of positions2
Button type1NO
Good but small
Good switch but the button is small so not thumb size but more pinky sized
This review has been posted for LB Aluminum Push Button with Blue Light 220V Ø12mm Silver
1NO type switch with blue indicator light. Operates from a bistable mechanism (two positions).  The connectors dedicated to the signal /...
