GENALEX GOLD LION KT88 Platinium Tetrode Tubes (Matched Quad)
This Genalex Gold Lion KT88 tube is a tetrode with equipotential cathode and is mainly designed to amplify low frequencies at an output stage. It has gold plated grids. It is an excellent equivalent to the 6550 tube.
4.7 / 5
By buying this product you get 26 loyalty points
Reference : 15683
261,90 €tax incl.
218,25 € tax excl.
Shipping date: 07-04-2026.
3 >Month warranty
Tubes Tetrodes (Matched Quad)
Genalex Gold Lion KT88 Tubes Tetrodes (Set x4 appairés)
1External metal screen
2Heater
3Plate
4Grid 2
5Grid 1
6NC
7Cathode
Product typeTetrode tubnes
Number of pins7
ApplicationLow frequency amplification in output stage
QuantityFour matched tubes
Measurements
ParameterConditionsMin.Max
First grid reverse currentFilament voltage 6.3V, plate voltage 400V, grid 1 voltage16.5V, grid 225V, resistance circuit grid 1 0.051MΩ-0.7µA
Heater current-1.5A1.7A
Plate currentFilament voltage 6.3V, plate voltage 400V, grid 1 voltage 16.5V, grid 2 voltage 225V75mA125mA
Grid 2 currentFilament voltage 6.3V, plate voltage 400V, grid 1 voltage 16.5V, grid 2 voltage 225V2mA9.5mA
Output powerFilament voltage 6.3V, plate voltage 400V, grid 1 voltage 16.5V, grid 2 voltage 225V, plate circuit resistance 3kΩ14W-
First grid cut-off voltage, negativeFilament voltage 6.3V, plate voltage 400V, grid 1 voltage 16.5V, grid 2 voltage 225V-58V
DistortionFilament voltage 6.3V, plate voltage 400V, grid 1 voltage 16.5V, grid 2 voltage 225V-18%
Contacts number7
Tube typeTetrode
15 reviews
indispensable!
acquis en quad appairé pour remplacer les electro armonicx montées d'origine depuis cinq ans sur mon feez audio titania (premiere generation) je suis ravis: un bon en avant pour mon système! équipé d'enceinte colonne lim audio pareto ( First Édition numérotée) je découvre un son aéré, des aigus naturels et des basses profondes sans outrance, un voile est levé! un vrai régal ces gold lion!
si j'avais su je les aurais installer au début de la vie de mon ampli.
n'ayant pas pu dialoguer sur le site pour avoir des infos, ou des conseils j'ai juste une critique sur le fait que le service d'audiophonics n'ai plus d'accueil téléphonique..
mis à part cela je félicite cette enseigne pour son serieux et ses tarifs avantageux.
Jean Michel.
This review has been posted for GENALEX GOLD LION KT88 Platinium Tetrode Tubes (Matched Quad)
Jadis DA30
Sur jadis DA30 odeur de brulé . J ai remis les GEKT Shugang .
really good
These now replace a good, stable quartet of JJ KT88s, which are underrated and which I, as a somewhat critical listener, have been happy with for a long time. To cut a long story short: they have now been running in for a few weeks and the Gold Lions are better in all sound-related aspects. I must add that from the very first minute, they sounded impressively free and open, yet accurate without any harshness. What's more, this quartet was absolutely perfectly matched! I assume that the matching is carried out by audiophonics, so kudos to them for their passionate accuracy! Thanks and best regards!
Pas fiables
Bonne représentation musicale, un peu grasse quand même mais agréable. Le gros problème est la durée de vie des tubes ! Un an , environ 80 heures max.
Dommage
Excellentissime
Cohérence exceptionnelle de bas en haut du spectre. Beauté des timbres, musicalité. Médium et voix incarnées. Grave profond et modulé. Une réussite sur mon Audiomat Solfège ref qui drive des Triangle Cello. Seul bémol comme déjà mentionné, 40 heures mini pour le rodage mais c'est pour le meilleur !
This Genalex Gold Lion KT88 tube is a tetrode with equipotential cathode and is mainly designed to amplify low frequencies at an output stage. It...
