SOVTEK 12AX7WB / 7025 Twin Triode Tube (Unit)
This double triode tube with equipotential cathodes Sovtek 12AX7WB/7025 offers a higher gain and saturation than the model 12AX7WA. This model is known for its musicality and the roundness of its reproduction.
Reference : 17622
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 08-05-2025.
3 >Month warranty
Sovtek 12AX7WB / 7025
Twin Triode Tube
Sovtek 12AW7WB / 7025 Tube Double Triode
This twin triode tube with equipotential cathodes Sovtek 12AX7WB/7025 offers a higher gain and saturation than the model 12AX7WA. This model is known for its musicality and the roundness of its restitution. It is particularly designed to amplify low frequency voltages. It can replace a 12AX7/ECC83 tube or be used in a DIY integration.
Sovtek 12AW7WB / 7025 Tube Double Triode Sovtek 12AW7WB / 7025 Tube Double Triode
Product typeTube
Tube typeTwin triode
Number of pins9
DimensionsØ22.5 x 56.5mm
Electrical parameters
ParameterConditionsMinMax
Heater currentFilament voltage : 6.3V300mA340mA
Filament voltage : 12.6V150mA170mA
Grid reverse currentFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 1.5V, grid circuit resistance 1MΩ-0.2µA
Plate currentFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 1.5V1.2mA3mA
First and second triodes plate current differenceFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 1.5V-±40%
Amplification factorFilament voltage 6.3V ou 12.6V, plate voltage 250V, grid voltage minus 1.15V951125
Limit values
Filament voltageParallel connection6V6.6V
Series connection12V13.2V
Plate voltage--300V
Cathode - Heater votlage--±200V
Cathode current--10mA
Power dissipation at the plate of each triode--1W
Grid circuit resistance for each of the triodesFixed bias-1MΩ
Self bias-2.2MΩ
Contacts number9
Tube typeDual Triode
This double triode tube with equipotential cathodes Sovtek 12AX7WB/7025 offers a higher gain and saturation than the model 12AX7WA. This model is...
