OYAIDE PA-2075 RR V2 Phono Interconnect Cable
The OYAIDE PA-2075 RR V2 is a phono interconnect cable featuring a high-end design that transmits a stable signal faithful to the original.
Reference : 19523
55,00 €tax incl.
45,83 € tax excl.
Shipping date: 13-06-2025.
Câble vendu au mètre
Oyaide PA-2075 RR V2 Phono Interconnect Cable OCC Pure Copper Double Shielded 2x0.5mm² + 1x0.3mm2 Ø12.4mm
OYAIDE PA-2075 RR V2 cable picture
The Oyaide PA-2075 RR V2 is a phono interconnect cable featuring a high-end design that transmits a stable signal faithful to the original.
Oyaide PA-2075 RR V2: OCC "102SSC" pure copper conductors
This cable features OCC "102SSC" pure copper conductors and a 3E multi-strand structure for enhanced conductivity. One of the special features of "102SSC" copper is that Oyaide removes 100% of impurities from the surface of the copper wire, polishing it with natural diamonds. 3E braiding" is a patented technology that geometrically twists strands of three different wire diameters to create a denser conductor.
The electrical capacitance of this cable is perfect for transmitting weak analog signals, thanks to its 110.0pF/m (1kHz) capacitance and 44 ohm impedance. It is therefore ideal for use with vinyl turntables.
102SSC copper
102SSC copper
3E structure
3E structure
Oyaide PA-2075 RR V2: efficient shielding and insulation
A shielding system consisting of approximately three times the number of wires used for the conductor, plus a layer of PVC carbon, effectively protects the cable against interference. As insulation, Oyaide has chosen fluoroplastic (PFA) and a layer of polyethylene. The whole is covered by a halogen-free polyethylene outer sheath to dampen vibrations during signal transmission.
OYAIDE PA-2075 RR V2 cable structure
Oyaide PA-2075 RR V2: high-end ground wire
The ground wire conductor is made of silver-plated copper for high conductivity, and its diameter has been increased for more effective grounding.
Technical ccharacteristics
Product typeRCA cable
Conductor materialPure OCC copper
ShieldingCarbon PVC
102SSC copper braid
InsulationPolyethylene and fluoroplastic (PFA)
Cable conductors AWG 0.5mm² (20 AWG)
Capacitance110.0pF/m (1kHz)
Resistance44 ohms
Total cable diameter5.2×12.4mm
External sheathHalogen-free anti-vibration
GROUND WIRE SPECIFICATION
Ground wire conductive materialSilver-plated copper
Ground wire cross-section0.3mm² (22 AWG)
Package1x Sold by meter
Diameter (mm)12.4
Length (m)Sold by length
Number of conductors3
Insulation materialCarbon
Insulation materialPFA
ShieldingYes
Section (mm²)0.50
Ground / ShieldingYes
OYAIDE PA-2075 RR V2 Phono Interconnect Cable OCC Pure Copper Double Shielded 2x0.5mm² + 1x0.3mm2 Ø12.4mm
The OYAIDE PA-2075 RR V2 is a phono interconnect cable featuring a high-end design that...
