[GRADE S] MINIDSP FLEX HT DSP Audio Processor
-10%
Refurbished product - Grade S
The miniDSP Flex HT is part of the miniDSP Flex range of advanced audio processors. This device is a 2x8-channel, multi-channel DSP processor featuring an HDMI ARC/eARC input. The miniDSP Flex HT features a complete suite of audio processing functions: bass management, parametric equalizers, crossover, advanced biquad programming and delay/gain controls.
Reduced price!
Reference : 20848
Refurbished
Limited special offer
999,00 €tax incl.
-10%
899,01 €tax incl.
749,17 € tax excl.
Product in perfect condition. Dirac license (normally paying) already included.
MINIDSP FLEX HT
Audio DSP Processor 2x8 Channels SHARC ADSP21489 XMOS HDMI ARC eARC
MINIDSP FLEX HT Processeur Audio DSP 2x8 Canaux SHARC ADSP21489 XMOS HDMI ARC eARC
With multiple digital inputs and eight unbalanced analog output channels, the miniDSP Flex HT can support active loudspeakers with up to four stereo channels. Flexible 2x8 signal routing allows many other configurations, such as two-way, three-way and multiple subwoofers.
The Flex HT features stereo digital inputs in USB-B, coaxial and Toslink optical formats. The HDMI ARC/eARC and USB inputs support 8 channels of linear PCM. A front-panel OLED display and volume control knob provide easy control of the device. Settings can be easily modified using Stereo Dirac Live® acoustic correction software.
The analog RCA output stage boasts excellent performance, with a THD+N of just 0.0003%.
This device is the perfect solution for users looking for an audio processor for a home-cinema or multi-channel Hi-Fi installation.
Please note that Flex HT does not support bitstream decoding (e.g. Dolby/DTS). The audio source must be capable of producing linear PCM (LPCM) for multichannel support via HDMI.
MiniDSP FLEX HT rear panel
1HDMI ARC/eARC input
2Power supply connector
3USB-B input
412V Trigger out
5Toslink optical input
6SPDIF coaxial input
78x Unbalanced RCA analog output
Product type2x8 channels DSP
Inputs1x HDMI ARC/eARC (up to 8 LPCM channels)
1x USB-B (up to 8 channels)
1x Coaxial (Stereo)
1x Optical Toslink (Stereo)
Ouputs8x RCA unbalanced
Other connectors12V Trigger
ProcessorAnalog Devices SHARC ADSP21489 400MHz 32bit floating point
USB interfaceXMOS
USB compatibilityWindows (ASIO Driver)
Mac OS
Linux
(Multichannel configuration up to 7.1 channels)
HDMI connectivityARC/eARC (up to 8 LPCM channels)
Supported sample rate : 20-216KHz
Output impedance200Ω
Max. output level2Vrms
Fréquency response20Hz–20kHz (±0.05dB)
SNR (D/A)125dB (A) with DRE
THD+N (D/A)-111 dB (0.0003 %)
Crosstalk (D/A)-120dB
Filtering technologyminiDSP DSP toolbox: routing, bass management, parametric EQ, crossover, gain/delay.
DSP presets4
HDMI CEC
Power supply12V 1.6A
Power consumption4.8W
2.9W (Standby)
Dimensions150 x 180 x 41mm
Package1x miniDSP FLEX HT
1x Remote control
1x Power cable
InputHDMI ARC
Max sampling rate48kHz
Max sampling rate192kHz
Refurbished GradeGrade S
Gros potentiel
Gros potentiel pour ce filtre actif, préampli et correcteur de pièce numérique. L'entrée HDMI LPCM / earc 8 voies permet par ex. de réalilser une filtration active stéréo 2 x 3 voies sur les enceintes principales et d'allouer les deux dernières voies pour les effets arrières, le tout tout en numérique et sur le même appareil et télécommande, sans passer par des conversions N/A et A/N fastidieuses. Pour celà, il faut bien s'assurer de disposer d'une connexion HDMI Earc sur le téléviseur ou acheter un boitier HD Fury Arcana par ex. pour la conversion PCM vers LPCM si seulement un vidéo projecteur est présent ou un téléviseur plus ancien.
La compréhension du routage et matricage est un peu complexe au début, il faut bien prendre son temps. Une fois celà assimilé, les possibilités sont énormes.
La qualité audio est au rendez vous comme d'habitude chez Minidsp, les convertisseurs sont de haute volée.
Je n'ai malheureusement pas pu essayer la correction DIRAC ni l'autoégalisation avec REW. Mais avec ce dernier logiciel, un micro de mesure et un peu de temps, il est facilement possible de régler un système actif en fonction de la pièce.
Si aucun intérêt pour le home cinéma, le Flex 8 sera suffisant.
Merci à l'équipe Audiophonics pour leur efficacité
This review has been posted for [GRADE S] MINIDSP FLEX HT Audio DSP Processor 2x8 Channels SHARC ADSP21489 XMOS HDMI ARC eARC
Refurbished product - Grade S The miniDSP Flex HT is part of the miniDSP Flex range of advanced audio processors. This device...
