The USB ddHiFi TC19CC is a USB cable with a high-end audiophile design. It features DATA conductors made of 4N monocrystalline pure silver and load conductors made of silver-plated OFC 5N copper, all implemented in a parallel structure with 4 flat conductors. The TC19CC COMET is therefore able to transmit an audio signal extremely reliably and stably, without any loss of data. Added to this is the fact that the cable's flat structure makes it as handy and flexible as it is robust and durable. On the connector side, there are two USB-C connectors with CNC-machined aluminum alloy bodies that reduce EMI/RFI interference. The gold connector is to be used on the source side for optimum performance. Practical and reliable, this USB cable is the perfect accessory for transmitting an audio signal from your source to a DAC or integrated amplifier. Available in a range of lengths, it's ideal for both nomadic and desktop use.
Product type | USB cable |
Length | 25cm |
Connectors | 2x Male USB-C |
Conductors | DATA: Pure monocrystalline silver 4N Charging: OFC copper 5N silver-plated |
Cross-section | DATA: 25.6AWG x2 (0.162mm² x2) Charging: 21.3AWG x2 (0.376mm² x2) |
DATA Shielding | Silver-plated OFC copper |
Insulating material | SoftFlex PVC |
Cable shape | Flat |
Color | Transparent / Silver |
Package | 1x ddHiFi TC19CC Comet cable |
Length (m) | 0.25 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | USB-C |
Conductors material (Cable) | Copper |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | Silver |
