Best usb cable I have tried. Clarity, precision, detail and big sound are some of its characteristics.
The Neotech NEUB-1020 class 2.0 AUDIO USB cable offers a formidable digital reproduction quality using innovative technologies that shake up the hierarchy of high-end USB cables. Designed with pure silver OCC monobrin wires for each DATA + and DATA part - this cable contains treasures of sound fidelity with a high-end polyethylene sheath and 100% EMI shielding.
Male USB-A to Male USB-B 2.0 Cable 24k Gold Plated UP-OCC Silver 1m
Designed with pure silver OCC monobrin wires for each DATA + and DATA part - this cable contains treasures of sound fidelity with a high-end polyethylene sheath and 100% EMI shielding. This USB cable has optimized gold-plated USB plug.
The OCC process allows to obtain a larger and purer crystal, with a purity rate of 99.9998%. This ultra pure conductor ensures a cable with low electrical resistivity, higher signal transmission speed and greater resistance to twisting, oxidation and corrosion.
Cable type | Male USB-A to Male USB-B |
Conductors material | Single crystal UP-OCC pure Silver conductor |
Connectors plating | Gold 24k |
External diameter | 6.2mm |
Shielding | 100% shielded cable. Eliminate EMI interferences. |
Insulation | High Quality Polyethylene |
Length | 1m |
Cable color | White / Silver |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | USB-A |
Connector | USB-B |
Conductors material (Cable) | Silver |
Conductors Plating (Cable) | None |
Average votes 4.8 / 5 13 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Dimitrios K.
Christian G.
Eric C.
Johan R.
Hugo F.
