Connector Female USB-A 3.0 on PCB
This USB-A 3.0 PCB connector allows for easy mounting with solder pads that have a 2.54mm pitch (not an XH connector). In addition, each solder pad is silk-screened for easy wiring and soldering.
Reference : 16485
2,50 €tax incl.
2,08 € tax excl.
USB Connector
Connecteur USB-A 3.0 Femelle sur PCB
Product typeFemale USB-A 3.0 connector
Mounting typeTo solder
PCB dimensions25 x 20mm
Mounting holes spacing20mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticFemale
ConnectorUSB-A
This USB-A 3.0 PCB connector allows for easy mounting with solder pads that have a 2.54mm pitch (not an XH connector). In addition, each solder pad...
