Parfait pour alimenter un raspi4 proprement avec un câble et une bonne alimentation
Male USB-C 3.0 DIY Connector
This connector to be mounted will allow you to create your own cables with USB-C connectors. This will allow you to take advantage of the reversible format of this connector, which can be plugged in both directions without making mistakes. In addition, USB-C takes advantage of the USB 3.0 standard for higher transfer rates.
| Specifications | |
| Product type | Male USB-C Connector |
| USB Standard | 3.0 |
| OTG | Yes |
| Contacts | x6 |
| Mounting | To solder (DY) |
| Dimensions | 16.2 x 8.6 x 3.1mm |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Male |
| Connector | USB-C |
| Contacts Material (Connector) | Copper Alloy |
| Contacts Plating (Connector) | Nickel |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
