FURUTECH FI-28M (R) Power Connector US Type B NEMA 5-15 Rhodium Plated Ø17.5mm
By buying this product you get 42 loyalty points
Reference : 6389
149,00 €tax incl.
124,17 € tax excl.
Last items in stock !
Shipping date: 07-01-2026.
US mains plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its contacts Copper plated Rhodium , the FI-28 also benefits from the proprietary anti-magnetism treatment FURUTECH Alpha α, which involves 2 steps:
1-Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FI-28 also uses the patented technology "Floating Field Damper System"which makes it possible almost completely to eliminate the creation of micro-zones of magnetic and electrostatic turbulence internally of the plug, perturbations caused by the passage of the current in the vicinity ofcertain sensitive component parts (metal fixing screws, cable clamping elements, etc.). These "floating" field micro-fields conflict with the much more powerful primary magnetic flux generated by the current flow through the cable and the connectors, thereby inducing a form of electrical resistance detrimental to conductivity, generate a form of distortion. FURUTECH succeeds in controlling these phenomena by connecting all the metallic parts concerned together with a conductor charged with bringing all these undesirable energies to the earth.
Its body of materialcompositenylon and fiberglassit demonstrates extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fixed by means of3 screws (2 poles + ground) marked with color code and whose firmness of maintenance, obtained thanks to the technology FURUTECH "Wire Clamp", makes it possible to exclude any risk of tearing or accidental deterioration of the cable, while significantly improving the contact surface.
Compatible with cables in the section is included between 6 and 17.5mm in diameter.
Features:/ Strong>
    • contactsCopper Pure Rhodium Plated
    • Anti-magnetism treatment FURUTECH Alpha α .
    • <li> Technology Owner
  • Nylon & Fiberglass Body
  • Screw plug (3 screws marked with color code)
  • Patented "Wire Clamp" Cable Tightening Technology (Improved Contact Area of ​​17%)
  • Compatible with Cables of Diameter between 6 and 17.5mm
  • Body Length: 76.2mm
  • Body Diameter: 39.6mm
  • 250V / 10A - 125V 15A
https://www.audiophonics.fr/images2/4718_FURUTECH-FI28R_3.jpg
https://www.audiophonics.fr/images2/6389/6389_FURUTECHFI-28M_1.jpg
https://www.audiophonics.fr/images2/6389/6389_FURUTECHFI-28M_2.jpg
IEC connector supplied separately
Max cable diameter (mm)17.5
Mounting typeTo weld
ConnecticMale
ConnectorType B (NEMA)
Rated current (A)15.0
