LM7805, Adjustable, +5V / +12V
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +5V is adjustable in the range +5V to +12V by means of a potentiometer. This controller provides low ripple, low noise and fast response. The controller only uses high-quality components such as a Toshiba low noise triode, Vishay resistors, VX Tantalum capacitors or a Bourns precision potentiometer.
The regulator is set to a basic voltage of +5V.
Product type | Discrete voltage regulator |
Regulation | Transistor NPN MJE15032G |
Adjustable output voltage | +5V to +12V |
Output current | 1A |
Operating temperature | 0°C - 125°C |
Max. voltage (Vin) | 35V DC |
Dimensions | 13.843 x 16.383mm |
Output voltage (V) | 7.0 |
Output voltage (V) | 5.0 |
Output voltage (V) | 6.0 |
Output voltage (V) | 10.0 |
Output voltage (V) | 9.0 |
Output voltage (V) | 12.0 |
Output voltage (V) | 8.0 |
Output voltage (V) | 11.0 |
Output current (A) | 1.0 |
Input voltage (V) | N/A |
