CLOUDYX CL-BOX WiFi Bluetooth 5.0 Receiver AirPlay 2 DLNA Multiroom Black
The CloudyX CL-Box is an extremely practical WiFi and Bluetooth receiver combo, allowing you to transform your audio installation into a true wireless system. Compact and stylish, it offers excellent performance and intuitive remote control.
Reference : 15017
99,00 €tax incl.
82,50 € tax excl.
CloudyX CL-BOX
CloudyX CL-BOX Récepteur WiFi Bluetooth 5.0 AirPlay 2 DLNA Multiroom
AKM AK4430 DAC
The conversion stage of the CL-Box uses a 24bit AKM AK4430 DAC chip. This benefits from an intelligent architecture that ensures very good audio performance, including a wide dynamic range, excellent linearity and low THD+N.
Multiroom
Compatible with Amazon multiroom and LinkPlay, the CL-Box will allow you to easily stream your music throughout your home. Its control application allows it to manage playback for each receiver in your different rooms.
WiiM Home Application & Streaming Services
The CL-Box receiver can be remotely controlled via your smartphone with the free WiiM Home application, available for Android and iOS. The latter allows you to manage the playback and distribution of your music for each CL-Box module installed. Moreover, the application is compatible with the most popular streaming services such as Spotify, Qobuz or Deezer.
Application Muzo Android Play Store Application Muzo iOS App Store
Product typeWiFi Receiver
ConnectivityWiFi 2.4G & 5G
Bluetooth 5.0
1x RJ45 (Ethernet)
Outputs1x Jack 3.5mm
1x Optical Toslink
DAC ChipAKM AK4430
WiFi Standard802.11 b/g/n
Supported WiFi protocolsAirPlay 2
DLNA
Ethernet type10/100Mbps
Output sensitivityJack 3.5mm output : 2V (1kHz 0dB)
Optical output : 0dB (1kHz 0dB)
THD0.03%
SNR95dB
Infrared receiver
Multiroom compatibilityAmazon
LinkPlay
Supported streaming servicesSpotify
Qobuz
Deezer
Tidal
Napster
iHeartRadio
Power supply5V DC via USB-C
Dimensions140 x 125 x 30mm
Package1x CloudyX CL-Box
1x Power adapter 5VDC 2A
1x USB-A to USB-C cable
1x Jack 3.5mm cable
InputWiFi
InputRJ45
OutputJack 3.5mm
OutputWiFi
OutputOptical Toslink
OutputBluetooth
Transmission / Reception protocolEthernet
Transmission / Reception protocolDLNA
Transmission / Reception protocolIR
Transmission / Reception protocolWiFi
Transmission / Reception protocolAirPlay
The CloudyX CL-Box is an extremely practical WiFi and Bluetooth receiver combo, allowing you to transform your audio installation into a true...
