Neat, little bluetooth dac we've got here which sadly has been ruined with a bad battery, it lasts only around 4 hours max instead of the 10+ told on the info here.
Bluetooth 5.0 Receiver CSR8675 MAX97220 NFC Silver
Extremely compact yet incredibly practical, the Hidizs H2 is a high-performance Bluetooth 5.0 receiver that will allow you to do without cables to enjoy your music. Simply pair the H2 with your smartphone to simply stream your music.
Bluetooth reception is provided by a Qualcomm CSR8675 chip. This high-performance chip supports numerous high-resolution codecs such as aptX, aptX-Hd, aptX-LL and LDAC. You will thus be able to enjoy your music in a practical way, without making any concession as for the sound quality.
The H2 also includes a MAX97220 amplifier chip, specially selected to perfectly accompany the CSR8675 Bluetooth receiver chip. This amplifier provides low distortion and noise for accurate, rich, and dense playback.
Bluetooth 5.0 offers excellent transmission speed and stability, while allowing a good reception distance. Ideal to enjoy a quality listening experience.
The H2 takes advantage of Qualcomm's 8th generation cVd noise cancellation technology. This technology helps reduce background noise during calls to ensure a clear conversation.
The UAT is a Bluetooth audio codec developed by HiBy to support sample rates up to 192kHz, with a bandwidth of 1.2Mbps.
Moreover, the H2 is compatible with the HiBy Blue application, displaying in real time the sample rate of the file being read and allowing access to an equalizer, gain levels or even firmware updates.
" />Sober, elegant and compact, the H2 is dressed in a resin frame. The control is simple and ergonomic, with only 3 buttons for pairing, volume control and playback. In addition, the H2 is able to automatically reconnect to the last paired device when it is turned on.
An LED indicator legibly displays the sample rate of the file being played back: green for files between 44.1kHz and 48kHz and blue for files between 88.2kHz and 192kHz.
The H2 is also delivered with a clip, allowing it to be attached to a pocket, for example, for practical use on the move.
| Specifications | |
| Product type | Bluetooth receiver |
| Bluetooth chup | Qualcomm CSR8675 |
| Amplification chip | MAX97220 |
| Bluetooth version | Bluetooth 5.0 |
| Supported Bluetooth codecs | UAT, aptX, aptX-HD, aptX-LL, LDAC, AAC, SBC, CVC |
| Power output | 2x 8mW @ 32Ω |
| Frequency response | 20Hz - 90kHz |
| THD+N | 0.008% (1kHz) |
| SNR | 92dB |
| Crosstalk | 768dB @ 32Ω |
| Recommended headphone impedance | 8-60Ω |
| LED Indicator | |
| NFC Pairing | |
| Compatibility | Android Windows Mac OS iPad OS |
| USB DAC Function | USB-C |
| Output | 1x Jack 3.5mm |
| Transmission distance | Approx. 10m |
| Battery capacity | 160mAh |
| Battery life | 7h |
| Charging time | 1.5h |
| General | |
| Dimensions | 32 x 32 x 10mm |
| Weight | 12g |
| Housing material | Resin |
| Color | Silver |
| Package | 1x Hidizs H2 1x USB-C Cable 1x Rear clip |
| Input | Bluetooth |
| Input | USB |
| Output | Jack 3.5mm |
| DAC / ADC Chip | NC |
| Color | Silver |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | aptX |
| Supported Bluetooth codecs | aptX LL |
| Supported Bluetooth codecs | AAC |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | LDAC |
| Supported Bluetooth codecs | SBC |
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric L.
