Bluetooth 5.0 Receiver Balanced DAC Headphone Amplifier 2x AK4377 MMCX
The Ikko Arc ITB05 is a combo Bluetooth and DAC receiver / Headset Amplifier symmetrical neckband format, taking advantage of an excellent design quality to promote a high quality sound reproduction. This model has a MMCX format connector to connect your headset or earphones. It will thus allow you to broadcast your music directly from your smartphone or tablet to the receiver. This means that there is no need for a cable between your headphones or earphones and your playback device.
The conversion and amplification stage of the ITB05 is based on a pair of independent AKM AK4377 DAC chips, each managing one channel for a fully balanced output. This architecture allows for high quality sound reproduction that is both accurate and transparent, with a significant reduction in noise.
Bluetooth 5.0 reception is provided by a Qualcomm QCC3034 chip, ensuring high signal stability. In addition, the QCC3034 is compatible with the standard Bluetooth codecs SBC and AAC, as well as with the aptX and aptX-HD, enabling high quality transmission without delay, up to 24bit 48kHz for the aptX HD.
| Specifications | |
| Product type | Bluetooth receiver DAC Headphone amplifier |
| DAC / Amplifier chip | AKM AK4377 |
| SNR | 120dB |
| THD+N | 0.001% |
| Bluetooth version | 5.0 |
| Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD |
| Bluetooth profiles | HSP/HFP, A2DP, AVRCP Spp, PBAP |
| Bluetooth distance | 10m |
| Connectors | MMCX |
| Charging connector | USB-C |
| Charging time | 2h |
| Battery life | 9h |
| Input | Bluetooth |
| Output | MMCX |
| DAC / ADC Chip | AK4377 |
| Color | Black |
| Transmission / Reception protocol | Bluetooth |
| Supported Bluetooth codecs | AAC |
| Supported Bluetooth codecs | aptX HD |
| Supported Bluetooth codecs | SBC |
| Supported Bluetooth codecs | aptX |
