- made in Lichtenstein
- easy to solder for a beginner
The Neutrik XX range follows the standard XLR cable connector for the X range, and offers several new features.
They are easy to assemble, with only four parts and no screws.
The contact block is made of hard plastic (polyamide) and is inserted through the back of the body.
The female contacts have a unique cage design with seven independent contact springs for low contact resistance and high integrity,
and incorporate a solder barrier to prevent the solder from flowing into the area of the mating contacts.
The female connector has a larger, easier-to-handle improved solid metal latch, plus additional new spring-loaded contacts for better body mass continuity.
Features:/ Strong>
Insulation material | PE |
Max cable diameter (mm) | 8.0 |
Mounting type | To weld |
Connectic | Female |
Contacts number | 3 |
Connector | XLR |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Silver |
Average votes 3.3 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Remus Andrei S.
Christian G.
jean francois G.
