Female 4 Pin XLR Plug Pure Copper Silver / 24k Gold Plated
The Viborg CF204G 4-pin XLR connector features superb build quality, using pure copper contacts with triple OFC copper, silver and 24k gold plating to ensure excellent signal transmission. The connector body is made of gold-plated brass and the insulation is PTFE. The base accepts conductor sizes up to 1.5mm² (16AWG).
| Specifications | |
| Product type | XLR plug |
| Contacts material | Pure copper |
| Contacts plating | OFC Copper Silver Gold 24k |
| Body material | Brass |
| Insulation | PTFE |
| Max conductors section | 1.5mm² (16AWG) |
| Mounting type | To solder |
| Rated current per contact | 10A |
| Rated voltage | < 50V |
| Total dimensions | 26 x 26 x 31mm |
| Max cable diameter (mm) | N/A |
| Mounting type | To weld |
| Connectic | Female |
| Contacts number | 4 |
| Max panel thickness (mm) | N/A |
| Connector | XLR |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Gold |
| Contacts Plating (Connector) | Silver |
