MOGAMI W3082 SUPERFLEXIBLE STUDIO Speaker Cable 2mm² Ø6.5mm
MOGAMI W3082 Câble Haut-parleur Superflexible Studio 2mm² Ø4.6mm
4.8 / 5
Reference : 6191
4,30 €tax incl.
3,58 € tax excl.
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Ce câble haut-parleur est conçu pour correspondre au diamètre des serre-câble des connecteurs XLR.
Sa conception coaxial est utilisée pour pouvoir fournir un conducteur de grosse section.
Grande taille des conducteurs de 2.0mm (près de 14 AWG).
SPECIFICATIONS
Configuration
Superflexible Studio Speaker Cables diagram w3082
Part No.
W3082
Conductor
Details
80/0.18 OFC (80×33AWG)
Size(mm²)
2.03mm² (Approx. #14AWG)
Insulation
Ov. Dia.(mm)
4.6Ø (0.181")
Material
PVC
Colors
White
Served Shield
Details
Size(mm²)
Jacket
Ov. Dia.(mm)
6.5±0.5ì (0.256±0.0197"ì)
Material
Flexible PVC
Color
Black
Roll Size
100m (328Ft) / 200m (656Ft) / 153m (500Ft)
Weight per 100m Roll
7.5kg
ELECTRICAL & MECHANICAL CHARACTERISTICS
Part No.
W3082
DC Resistance at 20°C
Inner Conductor
0.009W/m(0.0027W/Ft)
Same value for both internal and outernal/shield conductor)
Shield Conductor
Capacitance at 1kHz, 20°C
253pF/m(77pF/Ft)
Inductance
0.4µH/m(0.12µH/Ft)
Electrostatic Noise
0.2mV Max.
Electromagnetic Noise at 10kHz
0.2mV Max.
Voltage Breakdown
Must withstand at DC 500V/15sec.
Insulation Resistance
100000 MW × m Min. at DC 500V, 20°C
Flex Life
15,000 cycles
Tensile Strength
More than 980N
Emigration
Non-emigrant to ABS resin
Applicable Temperature
-20°C‾ +70°C(-4°F‾ +158°F)
Standard
UL13 CL2 75°C
https://www.audiophonics.fr/images2/6191/6191_MOGAMIW3082.jpg
https://www.audiophonics.fr/images2/6191/w3082f1.gif
https://www.audiophonics.fr/images2/6191/w3082f2.gif
Diameter (mm)6.5
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)2.00
Ground / ShieldingYes
19 reviews
Must try cable for speaker cables
For my DIY amplifiers with output power up to 40W per channel this cable is absolute favorite. Easy to assemble, flexible and more important absolutely transparent.
This review has been posted for MOGAMI W3082 SUPERFLEXIBLE STUDIO Speaker Cable 2mm² Ø6.5mm
Excellent cable
J'ai encore acheté ce câble pour un autre système.
A ce jour je n'ai pas trouve mieux et surtout a ce prix pour alimenter mes trois systèmes.
Il est vraiment au top.
Merci à Audiophonics pour avoir reçu le colis en 24H
Étonnant !
Câbles de 2 mm...
Il n'y aura pas de basses...
Quelle surprise dès la première écoute.
Un médium/aigu superbe, ultra détaillé et chaud quand même.
Quant à mon doute sur les basses et bien ils ont été balayé. Bien présente, sèche et profonde comme j'aime. Un peu moins présente il est vrai qu'avec mon ancien câble. Mais le gain de précision est tel que c'est parfait pour moi.
Cet avis n'est valable que pour mon système bien évidemment, mais au vu des avis positifs je ne doute pas que ce câble Mogami W3082 réjouira beaucoup d'audiophiles.
Source platine CD Rega Planet, platine vinyle Rega Planar 3 et cellule Denon DL 103 avec un petit transfo Anzaĩ et pré pré Talisman T6F
Lecture en dématérialisée sur ordi fait maison, lecture fichiers audio en Flac.
DAC Audiomat Tango 2.
Ampli musical fidelity M2si.
Enceintes Kit Focal 350 des années 1980.
pour mes " cabasse sampan "
possédant des enceintes cabasse sampan 305 , ayant la particularité d'avoir un haut médium légèrement sensible et projeté et après avoir lu sur le net plein d'avis d'utilisateurs de ce câble h/p , j'en ai donc commandé quatre mètres pour essai ! Je suis absolument satisfait du résultat , projection du haut médium très sensiblement atténué un aigu bien à sa place et le grave est tendu à souhait ! que du bonheur surtout à ce tarif .
Re
Et bien le voici avec quelques heures, jours de fonctionnement.. que dire: sur mon système, il est génial !
Mes enceintes sont très généreuses en basses et il lettrisme et ajusté tout cela. Les détails HF sont nombreux mais doux et subtils procurant souvent une surprise, une découverte. Il vient up grader mon système pour une bonne partie. Reste à essayer son cousin le 3103..
Bien sûr je le recommande sur un système bien basseux ou sur un bicablage HF.
