ARMATURE Cronos R2R Balanced XLR DAC 24bit/384khz XMOS XU208
ARMATURE Chronos R2R symetrical XLR DAC 24bit/384khz USB
4.8 / 5
By buying this product you get 74 loyalty points
Reference : 11831
749,00 €tax incl.
624,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
Armature Audio Cronos
24 bit 384 KHZ balanced XLR Armature Audio Cronos
Ultimate technology for connoisseurs
The DAC Armature Cronos concentrates the technological quintessence of the DAC R2R in a sober and elegant line. Equipped with the latest generation XMOS XU208 USB chip, Cronos will take you to audio landscapes where only music is queen.
A real DAC R2R dual mono conversion to XLR balanced outputs.
The Cronos Armature has all the functions and connections with a USB XMOS input derived from the Hecate XMOS XU208 SPDIF USB interface to play the High Definition files of your computer.
It also has two optical inputs and two SPDIF RCAs for all the digital connections imaginable (TV, consoles, CD players, internet box).
Its purified design without artifice is designed for the sole purpose of satisfying the knowledgeable music lover. The Cronos armature integrates a proprietary DAC with discrete components based on the R2R technology known as DAC to scale.
Cette technology is reputed to be the most faithful to the audio message. The digital audio message transmitted on an Altera FIFO DSP is sorted by 32 logic gates out of 192 resistors with a precision of 0.01% translating each high precision bit. A simple buffer stage with analog output with few components allows the most direct signal to the final listener.
PLM clock 24MHz / FIFO / AKM AK4118EQ / XMOS XU208
The digital path of the Cronos is based on a 24bit AKM AK4118 24bit SPDIF receiver on a 24MHZ PLL clock. The USB input has the XMOS XU208, a formidable processor with a processing power of 1000Mips to 8 cores that decodes the DSD 256 11.288MHz.
The whole thing goes through a FIFO DSP Altera MAXII reducing the jitter to its simplest expression. Thus the 192 resistors of 0.01% work under conditions of maximum decoding.
Altera Max II
Alimentation Armature Cronos
Oversized Power Supply
The Cronos Armature is based on a power supply with a large number of capacitors. This virtual battery process coupled to a toroidal transformer allows for a low noise level. Essential element this allows the respect of the smallest information of High Definition audio files.
Simple patterns
The CMC USA PTFE insulation and true symmetrical XLR gold-plated outputs are designed with an uncomplicated design. The symmetrical symmetry with an R2R converter on each side makes the DAC Cronos real separation of physical channels with insignificant crosstalk. Coupled with its low noise power supply with 5 LT1763 regulators, the Cronos delivers long hours of musical pleasure.
conception épurée
Intérieur Armature Cronos
Entries exits
inputs2x RCA SPDIF / 2x Optical Toslink / USB
ExitsRCA CMC USA gold plated / XLR symmetrical gold-plated
Various
Dimensions215 x 230 x 45mm
Chassis Material
AccessoriesPower cable
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD256
Max sampling rate384kHz
6 reviews
Très bon rapport qualité prix
Bonjour, je suis récemment passé à la dématérialisation. J'encourage Audiophonics à ce procurer les modèles supérieurs de cette marque...
Celui ci s'améliore avec le temps, un bon système de découplage (à bille chez moi) est bénéfique ainsi qu'un petit reclocker en entrée USB.
J'économise pour le modèle supérieur, à bon entendeur...
This review has been posted for ARMATURE Cronos R2R Balanced XLR DAC 24bit/384khz XMOS XU208
Article sur le convertisseur en R2R ARMATURE AUDIO Cronos
Le test du Cronos est à lire là:
http://audiovoluptesaddict.e-monsite.com/pages/tests/tests-sources/armature-audio-cronos/armature-audio-cronos.html
Les avis exprimés précédemment y sont partagés
le son clair
Très bon DAC
Essais avec amplificateur Sonic Frontiere à tubes ,enceinte haut rendement Supravox et CD tascam CD200 on gagne en transparence , en profondeur , en grave ,en micro- informations .Sans fatigue.
Dac très agréable le rapport qualité prix est excellent .J'aimerai ecouter son grand frère Asterion
Excellent DAC
Test et écoute après déballage suivi d'un Burn-in avec un cd Esoteric/Teac :
Les premières impressions sont excellentes.Restitution équilibrée,bonne aération,image profonde et assez large,finesse de l'aigu sans agressivité, bonne résolution,côté naturel et analogique de la reproduction,registre grave percutant,pas hyper rapide mais bonne extinction des notes sans traînage, aucun agressivité numérique .(écoute sur enceintes Apertura, ampli Creek Destiny 2,
lecteur Marantz premium sacd 12s2, câblage total Audioprana cryo. Argent +secteur dédié avec prises HMS). Ce dac mérite un fusible Furutech ou autre...
A suivre après rodage 300h et écoute attentive !
Très bon rapport qualité prix.
Excellent produit
J'ai longtemps eu une source micromega mydac pour alimenter mon prima luna prologue et des enceintes sonus faber toy tower. L'achat d'un petit dac r2R schiit modi multibit a été une première révélation : le côté naturel et charnel de la signature sonore, des basses présentes et percutantes...Je suis revenu d'un certain scepticisme vis à vis des dac et j'ai eu envie de creuser la piste des DAC R2R avec l'Armature Cronos au vu des excellents retours qu'il a partout sur le web. Et c'est encore mieux que le modi multibit, plus transparent, plus fin, une scène sonore plus étendue et ce côté naturel très immersif.
La construction a l'air sérieuse. Un petit bémol sur les voyants lumineux pas hyper lisibles
