RaspDIGI LTE LVDS Reclocker KALI - Streamer I2S LVDS HDMI Audio-GD compatible
AUDIOPHONICS RaspDAC LTE Network player I2S LVDS HDMI Audio-GD compatible
Audiophonics returns with a whole new version of its RaspDIGI LTE, intended for seasoned audiophiles. It includes a Raspberry Pi 3, a Allo Kali reclocker and an I2S to HDMI Audio-GD output module. So you can enjoy a really HiFi I2S signal and the resulting sound quality.
Reference : 12031
249,00 €tax incl.
207,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
To place an order, please specify the brand and model of the DAC you want to use in the "Product Customization" tab of this page.
In case of doubt about the compatibility and / or operation of this product, do not hesitate to contact us.
RASPDIGI LTE I2S LVDS HDMI
Raspberry 3 player - I2S LCD HDMI
Raspdigi LTE I2S LVDS HDMI
The dematerialized at your fingertips
Go to the high definition dematerialized with Rap DIGI LTE and its signal management I2S LVDS. Aluminum and Plexiglass case, Allo Kali Reclocker, Raspberry Pi 3 and I2S to HDMI module!
It is an affordable solution of dematerialized reading assembled and tested in our workshops, in France. Completely ready and ready to use electronically, you just have to choose the software solution of your choice (piCorePlayer, Max2Play, OSMC ...).
max2playpicoreplayerosmc
I2S LVDS: The ultimate in audio quality
Rather than using the usual signals, this RaspTouch offers you to enjoy a clean I2S signal.
Thus, an I2S FIFO 44 / 48MHz Allo Kali reclocker allows the Raspberry Pi I2S signal to be processed with an Ultra Low jitter fed by LDO and an ultra quiet power supply, providing high precision. The performance of your system is not delayed: your music "opens", your sound scene expands and you can now distinguish sounds until then inaudible.
This signal is then routed to an Audio-GD I2S to HDMI module, which balances the signal. All you have to do is connect your DAC and enjoy.
Kali
Many compatible DACs
Pour profitez de votre platine RaspTouch il vous suffit de choisir votre DAC HDMI, comme par exemple l'Audio-GD DAC-19 ou l'Audio-GD NOS-19. Bien sûr de nombreux autres modèles existent. Voici la liste des marques en proposant (non exhaustive) :
  • Astin Trew
  • Audio Byte
  • Rockna
  • Javs
  • K&K Audio
  • Love Harmony
  • PS Audio
  • Sonore
  • Stahl Tec Optus DAC
  • Wired 4 Sound
Raspdigi LTE DAC Audio-GD
A sober and elegant design
The RaspDIGI LTE proves to be a sober and elegant system that will integrate without difficulty within your Hifi system. The Raspberry Pi 3 trio, Allo Kali Reclocker and I2S / HDMI Audio-GD interface integrated in an Aluminum and Plexiglas case designed in our workshops will be protected from possible shocks and dust.
Raspdigi lteraspdigi dac audio-gd
Connectors
Input4x USB-A
1x Ethernet RJ45
1x Micro SD slot
Output1x HDMI (I2S LVDS)
1xHDMI Vidéo
Raspberry Pi 3
SoCBroadcom BCM2837 1.2GHz
CPUARM Cortex-A53 1.2GHz quadcore
Wifi802.11b
Bluetooth4.1
GPUCoprocesseur Multimédia IV VideoCore Double Coeur
RAMLPDDR2 1Go
Allo Kali
FIFO CircuitWith FPGA
FIFO MemorySRAM 4Mb
ClockMulti-frequency with automatic commutation
Voltage regulatorUltra low noise
Dimensions102 x 169 x 58mm
Weight606g
Power supplyJack DC 5.5/2.1mm - 5V 3A
AccesssoriesAlimentation cable 5V 3A
Mapping I2S / LVDS
A synthesis of main IIS on LVDS pinouts mapping is available here.
OutputI2S LVDS via HDMI
Product customization
After saving your customized product, remember to add it to your cart.
Text
loader
* required fields
Très bon Streamer
J'ai acheté ce streamer pour remplacer un PC portable avec Fedolight RT 22 + squeezelite en USB.
Je l'ai acheté avec une entrée I2S que j'ai installé sur mon Audio-GD 2015, j'ai installé PicoPlayer dessus et Je ne suis pas déçu, j'obtiens une vraie plus-value : Plus d'aération, de finesse et donc de plaisir. Je le recommande.
Pour info, j'ai eu des soucis avec l'entrée I2S prise en même temps et sur laquelle j'ai dû inverser 2 fils pour qu'elle fonctionne. Je remercie le suivi d'Audiophonics sur ce point
This review has been posted for RaspDIGI LTE LVDS Reclocker KALI - Streamer I2S LVDS HDMI Audio-GD compatible
Audiophonics returns with a whole new version of its RaspDIGI LTE, intended for seasoned audiophiles. It includes a Raspberry Pi 3, a Allo Kali...
