The Tonewinner SW-D9000 active subwoofer is a bass reflex subwoofer equipped with a 45.72cm driver for an RMS power of 1500W under 3Ω, and can reach 8000W at peak. It offers numerous options such as crossover frequency adjustment, 7-band equalisation, volume control and 0°-180° phase inversion. Six vents on the front panel improve bass response. In terms of inputs, you can choose between an RCA line input or two other inputs: single-ended RCA LFE and balanced XLR. Furthermore, the SW-D9000 also offers an LFE output.
In order to deliver powerful bass, the SW-D9000 has been equipped with an impressive 45.72cm diameter driver coupled with a 115mm voice coil and a dual magnet circuit. This configuration allows you to get the most out of the 1500W Class D amplification, ensuring powerful and dynamic bass reproduction, capable of reaching frequencies as low as 11Hz.
Thanks to the Tonewinner app available on Android and iOS, the SW-D9000 offers 7-band equalisation settings, crossover frequency adjustment and phase inversion, allowing you to perfectly tailor your subwoofer's performance to your listening environment and usage.
| 1 | Power supply voltage switch |
| 2 | Power switch |
| 3 | Power socket |
| 4 | Fuse |
| 5 | Sub XLR input |
| 6 | Sub RCA input |
| 7 | Sub output |
| 8 | RCA line input |
| 9 | Volume control |
| 10 | Mute function / Confirm button |
| 11 | Menu button |
| 12 | LCD Screen |
| Specifications | |
| Product type | Active subwoofer |
| Driver diameter | Ø45.72cm |
| Amplification type | Class D |
| Power output | RMS : 1500W Max : 8000W |
| Frequency response | 11Hz - 200Hz |
| Phase setting | 0 - 180° |
| Impedance | 3Ω |
| DSP / EQ | |
| Inputs | 1x LFE XLR 1x LFE RCA 1x RCA stereo line in |
| Output | 1x LFE RCA |
| General | |
| Dimensions | 630 x 695 x 832mm |
| Weight | 87kg |
| Color | Black |
| Package | Vendu à l'unité |
