HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x64V
The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a nominal power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by HYPEX to provide the 2 x 64V voltage required for the operation of the brand's UcD™ amplifier modules.
By buying this product you get 23 loyalty points
Reference : 8574
239,00 €tax incl.
199,17 € tax excl.
Hypex SMPS1200A400
Hypex SMPS1200A400 Module d'Alimentation à Découpage 1200W / 2x64V
Hypex SMPS1200A700 Module d'Alimentation à Découpage 1200W
Product typeSwitching power supply
Input voltage range190-250V AC (on main power plug 220V)
95-130V AC (on main power plug 110V)
Output voltage2x64V DC
Max power1500W
Nominal power1200W @ 20Hz
Switching frequency100kHz
Dimensions165 x 105 x 55mm
Weight750g
ProtectionOver-voltage
InputPCB Connector
OutputPCB Connector
Output voltage (V)64.0
Output voltage (V)2x64
Output current (A)NC
Input voltage (V)95.0
Input voltage (V)230.0
Input voltage (V)110.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)120.0
Input voltage (V)100.0
Input voltage (V)190.0
Input voltage (V)130.0
Input voltage (V)210.0
Input voltage (V)240.0
Power SupplySMPS
2 reviews
Excellent
Acheté en remplacement d'une alim similaire cramée après 6 ans de bons et loyaux services suite à une mauvaise manipulation.
Excellente qualité de fabrication, composants de qualité, notice très détaillée. Bien sous tout rapport.
This review has been posted for HYPEX SMPS1200A400 Switching Power Supply Module 1200W 2x64V
Great
Works very well. No pops or clicks through speakers. Manual is not easy for an amateur. But all info is there.
The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a nominal power of 1200 Watts in an extremely small...
