olivier P.
Déception !!…
Matière sans doute qualitative .. mais finition très moyenne un brin corrodée et mal ébavurée… on trouve mieux à 10 fois moins...
Maik B.
Maik B.
Fast shipping.
The sound is excellent. Ranked 5th out of many...
List of products DD HIFI
  • Ref : 20809
    With the HS300, ddHiFi offers an anodised aluminium tray designed to provide excellent heat dissipation as well as offering an aesthetic that is both sober and elegant. This tray is part of a set of components that allow you to create your own modular HiFi stand to suit your needs perfectly. In the same range, you'll find a set of aluminium feet in...
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 20813
    With the SR70, ddHiFi offers a set of 4 aluminum feets that can be nested together. These are designed to be fitted onto the trays in the same range to create a modular piece of HiFi furniture to suit your needs perfectly. All screws and bolts are supplied.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 20812
    With the SR85, dd HiFi offers a set of 4 aluminium legs that can be nested together. These are designed to be fitted onto the trays in the same range to create a modular piece of HiFi furniture to suit your needs perfectly. All screws and bolts are supplied.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 17806
    In Stock
    The DD TC07S cable consists of a male USB-C OTG connector on both sides. The cable features an optimized structure with perfect separation of the data and power conductors to avoid interference. The data conductors are made of pure silver, while the power conductors are made of OFC copper, providing excellent conductivity.
    44,90 € 37,42 €Ex.
    In Stock
  • Ref : 20692
    In Stock
    The USB-C ddHiFi TC09S cable benefits from a perfectly mastered design, using very high quality components in order to offer excellent conductivity and therefore signal transmission. Thus, its conductors are made of pure silver Litz wire for the data part and OFC copper for the power supply.
    79,00 € 65,83 €Ex.
    In Stock
  • Ref : 20690
    In Stock
    With the TC44PRO M3, ddHifi presents a portable DAC based on two CS43198 DAC chips from Cirrus Logic with a sleek design and a 3.5mm and 4.4mm jack output. This small portable DAC is capable of handling a signal up to PCM 32bit 384kHz and DSD256, and is designed to accompany you wherever you go and adapt to any situation.
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 20684
    The result of a collaboration between ddHiFi and Moondrop, Surface in-ear monitors feature a sophisticated five-driver hybrid system for extended, balanced frequency-band coverage. This configuration combines four Balanced Armature (BA) drivers and one Dynamic Driver (DD), orchestrated by Moondrop's expertise in crossover design, to deliver a natural...
    279,00 € 232,50 €Ex.
    In Stock
