Extension Male Micro SD to Female Micro SD 15cm
This extension consists of a male Micro SD connector and a female Micro SD reader. The female connector opens and allows you to effectively lock your Micro SD card inside. Particularly flat, this extension cable benefits from a beautiful design quality with tinned copper conductors with a section of 0.0509mm² and 0.0810mm², each being insulated by a PE sheath and then covered with an external TPE sheath. The contacts of the connectors are gold plated to promote good conductivity and resistance to oxidation.
Product type | Micro SD extension |
Length | 15cm |
Connectors | 1x Male Micro SD 1x Female Micro SD |
Conductors material | Tinned Copper |
Contacts plating | Gold |
Micro SD category | UHS-I |
Insulation | PE |
External sheath | TPE |
Color | Black |
