TRIANGLE Elana LN01A Active Speakers Bluetooth aptX 2x50W 89dB 56Hz-22kHz Abyss Blue (Pair)
20%
Triangle's Active Series speakers are the next generation of ultra-connected HiFi speakers. You can listen to your music from your phone, tablet or turntable and enjoy immersive and dynamic stereo sound. A true all-in-one HiFi system, the LN01A integrates a 2x50W Class D amplifier allowing you to fully enjoy your music.
Reduced price!
Reference : 16363
Limited time offer:
449,00 €tax incl.
-20%
359,20 €tax incl.
299,33 € tax excl.
Last items in stock !
Shipping date: 01-07-2025.
Triangle ELana LN01A
Triangle LN01A Enceintes Actives Bluetooth aptX 2x50W 89dB 56Hz-22kHz Bleu Abysse (La paire)
Enjoy your vinyl with ease
With the LN01A, Triangle has thought of vinyl lovers. No need to add a dedicated preamplifier to listen to your favorite records, your turntable can be directly connected to the speakers thanks to the integrated phono input.
Bluetooth aptX
With these speakers, the emphasis is on connectivity and ease of use. They are indeed equipped with a Bluetooth 4.0 AD2P receiver compatible with the high-definition transmission codec aptX, allowing to read audio streams up to 16bit 44.1kHz. The use is thus very easy while preserving a remarkable audio quality.
A complete connectivity
With their numerous inputs, the LN01A can be integrated into a home cinema configuration. A subwoofer output even allows the addition of a possible subwoofer (not supplied) for even deeper bass.
Product typeActive speakers
Speaker typeBass Reflex
Number of drivers2
DriversTweeter 25mm
Woofer 13cm
Recommended room size15 to 30m².
Sensitivity89dB/W/m
power handling2x50W
Bandwidth (+3dB)56Hz - 22kHz
Min/Max nominal impedance4.5 / 8Ω
ConnectivityBluetooth
1x Stereo RCA
1x AUX Jack 3.5mm
1x Optical
1x Coaxial
1x Subwoofer output
Supported Bluetooth codecsaptX
Dimensions165 x 235 x 291mm
Weight9.5kg
ColorBlue
QuantityPair
ColorBlue
Impedance (Ω)8
Impedance (Ω)4
Efficiency / Sensitivity (dB)89.0
Lowest frequency (Hz)56
Highest frequency (Hz)22000
Power (W)50.0
Number of ways2
Speaker typeActive
Speaker form factorBookshelf speaker
Triangle's Active Series speakers are the next generation of ultra-connected HiFi speakers. You can listen to your music from your phone,...
