The Cosmos Scaler is a low-noise, variable-gain preamplifier designed specifically for the brand's Cosmos ADCs. It incorporates quality components such as two OPA1612 and two OPA1656 AOPs. It features 16 gain positions from 0 to 26dB, plus an automatic adjustment position.
Eversolo returns this time with its DMP-A8, a network player and DAC of the highest quality and incredible versatility. A true centerpiece of today's HiFi system, it offers a wide range of uses, from local file playback to accessing your music library from network devices or your favorite streaming applications. Its meticulous design also ensures the...
Ferrum's OOR is a high quality balanced headphone amplifier and preamplifier, capable of accompanying all types of headphones, including the most demanding, while preserving the essence of your music. With very low distortion, impressive dynamics and an incredible level of detail, the OOR is the ultimate companion for headphone listening.
FiiO offers us the evolution of their K9 model. The K9 AKM is a versatile DAC model integrating analog and digital inputs, and can be used in USB DAC mode. This model features a latest-generation AKM DAC coupled with its Delta-Sigma modulator, enabling music playback at resolutions of up to 32 bits / 768kHz and DSD512 file decoding. These two THX...
With its R9, FiiO unveils an extremely versatile high-performance desktop device. The R9 functions as a DAC, network player and headphone amplifier. Two ES9038Pro DAC chips enable it to decode high-resolution streams up to PCM 32bit 768kHz, DSD512 and MQA, while its RJ45 port and large display give you easy access to all streaming services: Tidal,...
The Fosi Audio P3 is a compact, high-performance preamplifier. It features two JAN 5654W tubes and a QCC3031 Bluetooth receiver chip. A 3.5mm jack is also available on the front panel, with volume and tone controls for bass and treble.
With its SK02, Fosi Audio unveils a small, versatile, high-performance device that takes up the form factor of its SK01. The SK02 fulfills the functions of headphone amplifier, portable preamplifier and portable DAC. The SK02 features an ES9038Q2M DAC chip and a low-noise,...
The Fosi Audio Tube-P1 presents itself as a compact, efficient and low cost tube preamplifier. Equipped with two 6K4 tubes, it offers a musical and warm sound reproduction, typical of this type of design.
FX-Audio's DAC-A10 is a versatile, high-performance tube DAC/preamplifier with a relatively compact form factor. It is based on quality components such as an ESS ES9018K2M DAC chip and two 6N3 tubes for the preamplifier stage.
The 6J1 FX-Audio TUBE-01 tube buffer preamplifier is a smart little tool to improve the sound of a desktop DAC or HiFi installation. With a gold-plated stereo input and output, it will be a quality companion coupled with a Class D power amplifier.
With the Tube-02 Pro, Fx-Audio offers a small tube preamplifier and headphone amplifier in a compact and affordable format. Its preamplifier stage uses a pair of 5725 tubes, giving it a soft and round sound. The buffer of the Class A headphone amplifier section uses transistors to provide a nice energy reserve to accompany many types of headphones.
The FX--Audio Tube-03 MKII is an update of the Tube-03E. It is an affordable two-tube 6k4 preamplifier. Complete and powerful, with its own volume control and adjustments for bass and treble levels. These tubes are associated with AOP NE5532 and JRC4556 for tone control and participate in a rich and musical sound reproduction.
The FX--Audio Tube-03 MKII is an update of the Tube-03E. It is an affordable two-tube 6K4 preamplifier. Complete and powerful, with its own volume control and adjustments for bass and treble levels. These tubes are associated with AOP NE5532 and JRC4556 for tone control and participate in a rich and musical sound reproduction.
The Tube-05 is a compact device from FX-AUDIO. This desktop headphone amplifier/preamplifier is based on the use of an ECC82 tube. It features an innovative appearance and form factor, as well as quality components such as WIMA and Nichicon capacitors and a JRC NJW1194 volume control chip with output selector and tone control.
The FX-Audio TUBE-06 MKII is an affordable and efficient tube preamplifier. Its preamplifier stage is based on the use of a pair of 6N3 tubes. It is associated with a digital/analog conversion section using an ESS ES9018K2M DAC chip, a CM6642 USB interface or other quality components such as NE5532 and OPA2134 AOs. It is thus capable of a musical and warm...
With the DAC, Gustard offers a high-performance headphone amplifier and preamplifier, benefiting from careful and intelligent manufacturing. With its independent symmetrical and asymmetrical circuits and capable of delivering a high level of power, it can be used with most of the headphones on the market.
With its H26, Gustard unveils a class-A balanced audiophile preamplifier/headphone amplifier featuring discrete components. It features 8 pairs of power transistors, two dual LME49720 AOPs, two toroidal transformers, a relay volume control matrix and a balanced architecture.
Gustard P26 is an elaborate preamplifier / volume controller / strain selector (3 inputs). It will delight audiophiles looking for a fully balanced circuit.
This beautifully crafted Hattor Audio passive/active preamplifier features two high precision attenuators with Takman REX AMRT carbon film resistors, ensuring very low distortion for pure and transparent sound reproduction. It offers the latest refinement in high-end preamplification.
This superbly crafted Hattor Audio The Big passive preamplifier features two precision 1% SMD resistor attenuators and offers the very latest in sound reproduction refinement. Both a passive preamplifier and a input selector with generous connectivity (2x RCA & 3x XLR IN / 2x RCA & 2x XLR OUT), this impeccably finished, hand-assembled device is an...
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier and selectors for 5 sources and 4 outputs, this device with its aluminium and black carbon finish will convince. It is equipped with very high quality components assembled by hand...
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier and selectors of 5 sources and 4 outputs, this device with its aluminium and wood finish will convince. It is equipped with very high quality components assembled by hand with the...
The Hattor Audio Tube Active Stage is a very high quality gain/buffer stage. It has been thought and designed mainly to be associated with the passive preamplifiers of the brand. However, it can also be used with other passive preamplifiers.
With its Serenade, HiFiMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and network player, thanks to an RJ45 LAN port. The device was developed by HiFiMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A headphone amplification...
Holo Audio offers with the Serene a fully balanced, high performance preamplifier based on a discrete component design. The left and right channels are separated, each with independent amplifier modules. It also benefits from a two-stage buffer and amplifier section. The preamplifier concentrates largely on its attenuation performance and ensures...
Holo Audio unveils with the Spring 3 a beautiful R2R DAC / preamplifier based on discrete components. Custom designed, it offers incredible performances thanks to its Trickle Down technology. Its particular architecture allows it to deliver a sound restitution of an unbelievable richness and purity. It embeds two totally separate circuits, one in charge...
With its NEO iDSD 2, iFI Audio unveils an upgraded version of the NEO iDSD, fulfilling the functions of DAC / Preamplifier / Headphone Amplifier. The NEO iDSD 2 is one of the first DACs to integrate Bluetooth aptX Lossless technology. Versatile and high-performance, the NEO iDSD 2 can be used in a variety of ways: DAC/headphone amplifier, pure DAC coupled...
The iFi Pro iCAN SIGNATURE tube preamplifier and headphone amplifier is the quintessence of the know-how of the brand itself supported by the prestigious company AMR. Based on a hybrid circuit of transistors and tubes, the iFi Pro iCAN SIGNATURE embeds the best of these two technologies and not a caricatural compromise.We can therefore choose the sound as...
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with high-end components, it provides a high quality sound reproduction that is as rich and precise as it is dynamic.
this passive attenuator uses a precision resistor that is connected in parallel with a 1% SMD mechanical resistance switch. this resistor is connected to the potentiometer, which, depending on its position, more or less connects the output to ground and thus varies the volume.
Both passive preamplifier and source selector, this aluminum and wood finish unit will surely convince you. It is equipped with very high quality components assembled by hand with the utmost care. In addition to its magnificent realization, this volume controller has the best technical features.
