The Wondom AA-AB32221 is a stereo amplifier module capable of delivering 2x140W of power at 4Ω. Featuring a Class D architecture based on a TAS5613 amplifier chip, it achieves a very high efficiency of 96% and excellent sound quality with very low distortion and noise level. Its SNR is thus measured at 94dB and its THD+N at 0.019% (@ 4Ω, 1W, 1kHz).
This small Class D AB32231 amplifier module from Wondom is based on a TPA3110 amplifier chip. It is capable of operating in stereo mode by delivering 2x8W and in mono mode by delivering 1x16W.
The Class D Wondom AA-AB32255 amplifier module is based on a TAS5756 chip from Texas Instruments (TI). This allows it to deliver a power of 2x30W at 4 Ohm and this with a high efficiency of 90% and a precise sound reproduction.
The Wondom AA-AB32256 module is a high-performance Class D amplifier with an integrated audio processor. It is based on an amplifier chip TI TAS5754, allowing it to develop a power of 2x30W under 4Ω (THD 10%) with a high efficiency.
The Wondom AA-AB32281 is a stereo amplifier module capable of delivering 2x128w of power at 3Ω. Featuring a Class D architecture based on Sure Electronics' T-Amp technology, it achieves a very high efficiency of 91% and excellent sound quality with very low distortion and noise level. Its SNR is measured at 94dB and its THD+N at 0.004% (@ 3Ω, 1W, 1kHz).
The Wondom AA-AB32361 is a stereo amplifier module capable of delivering 2x110w of power at 4Ω. Featuring a Class D architecture based on a TDA7498E amplification chip, it achieves a very high efficiency of 95% and excellent sound quality with very low distortion and noise level. Its SNR is measured at 87dB and its THD+N at 0.032% (@ 4 Ohm, 1W, 1kHz).
This Class D Wondom AA-AB32433 stereo amplifier is capable, thanks to the T-Amp technology, of developing a consistent power of 2x750W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models.
This Class D Wondom AA-AB32516 stereo amplifier is capable, thanks to T-Amp technology, of developing a consistent power of 2x500W at 4Ω with an efficiency of 90%. This large energy reserve allows it to be combined with a large number of speakers, including the most demanding models.
This amplifier module from WONDOM is a powerful 3-channel module. Powerful, it delivers up to 2x300W and 1x 500W @ 3 Ohm (THD+N = 10%). This module is based on Class D architecture and T-AMP technology, enabling 97% efficiency while maintaining high sound reproduction quality and low levels of noise and distortion.
This Wondom AA-AB35281 multi-channel amplifier uses T-Amp technology allowing it to deliver a consistent power of 3x200W under 3Ω with a high efficiency of 94%. This energy reserve allows it to be associated with a wide range of speakers, including demanding models.
Wondom's Brick DBKL3 amplifier module offers impressive 900W mono amplification at 2Ω, based on discrete components. It was developed to meet a wide range of requirements for a wide variety of DIY applications. The module has a wide load impedance range and is equipped with numerous protections, making it both a flexible and reliable amplifier.
The Wondom AA-BK31382 is a mono Class D amplifier module capable of delivering no less than 2000W at 2Ω and this with a high efficiency of 90% as well as a high level of detail and very good dynamics.
To facilitate the use and integration of JAB3+, JAB4 and JAB5 modules, Wondom offers a kit containing all the cables and accessories needed to fully exploit their functionalities.
As part of the JAB range, the JAB2 offers a wireless amplification solution with an integrated Bluetooth receiver module that can be powered directly by Lithium batteries. This mono version is capable of delivering 100W of power at 2Ω thanks to a high performance TPA3116 amplifier chip. The module efficiently dissipates the heat from the amplifier thanks...
Wondom's JAB2v2 is a 1x 60W Class D amplifier module with high-resolution Bluetooth 5.0 connectivity and DSP so you can shape the sound to your liking. Moreover, this module has a mixed line output for use in conjunction with other amplifier modules to create 2.1 or 4.0 setups.
The Wondom AA-JA32151 JAB 1 is a versatile Bluetooth 2.1 stereo amplifier module delivering 2x15W at 8Ω. This new wondom JAB series offers amplification modules for mobile use. They are optimized for Lithium battery operation. It is possible to use them in mono mode (BTL).
Wondom's JAB2+ is a stereo amplifier module featuring a Bluetooth 5.0 module and integrated DSP. The JAB2+'s amplification is based on a Texas Instrument TPA3116 chip capable of delivering 35W per channel at 4Ω. For furthermore flexibility, it is also possible to configure a single 100W output at 4Ω.
Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
The WONDOM AIPO2X3 amplifier module is a small stereo amplifier module capable of delivering 2x3W @ 4 ohms thanks to a Class D PAM8408 amplifier chip with integrated volume control.
This module offers a wide range of connectors to easily connect a module and a power supply with different connectors. Real Swiss Army Knife of power supply connectors.
The Wondom CVA-1100 is a 100W amplifier module, consisting of a power section and an amplifier stage. It is primarily designed for distributed speaker installations, such as background music systems. It is capable of delivering 70/100V RMS continuous power without the need for an output transformer, thus reducing the footprint while improving the...
With the DKT2X20AB, Wondom offers a DIY kit to assemble a 2x20W Class AB amplifier module yourself. Designed with a TDA7576B chip, this kit offers 20W output per channel at 4Ω, guaranteeing high-fidelity sound with low noise. Equipped with a robust heatsink, the DKT2X20AB benefits from an optimal cooling design for increased durability and longevity.
With the DKT2X20D, Wondom offers a DIY kit to assemble a 2x20W Class D amplifier module yourself. Designed with two MP7720 AMP integrated circuits, this kit offers an output of 20W per channel at 4Ω, guaranteeing high-fidelity sound with low noise and high efficiency.
With the DKT4X25AB, Wondom offers a DIY kit to assemble a 4x25W Class AB amplifier module yourself. Designed with a TDA7569BLV chip, this kit offers an output of 25W per channel at 4Ω and has been designed for use as a car radio amplifier. Equipped with a robust heatsink, the DKT4X25AB benefits from an optimal cooling design for increased durability...
