This TDA7850 class A/B amplifier module with MOSFET technology features 4 channels and is capable of delivering 4x50W output power at 4 ohms. The TDA7850 chip, mounted on a heatsink for efficient heat dissipation, is the reason for its high power and rich, detailed sound reproduction. This module offers high output current thanks to its rail-to-rail output structure and low distortion. Input is via a double RCA socket, and output is via screw terminals. This amplifier module accepts a voltage range from 12V DC to 18V DC, also via screw terminals.
1 | DC 12V-18V power supply input on screw terminal block |
2 | RCA stereo input 1 |
3 | RCA stereo input 2 |
4 | Output 1 on screw terminal block |
5 | Output 2 on screw terminal block |
6 | Output 3 on screw terminal block |
7 | Output 4 on screw terminal block |
Product type | 4.0 amplifier module |
Amplification type | Class A/B |
Amplification chip | TDA7850 |
Number of channels | 4.0 |
Inputs | 2x RCA stereo |
Outputs | 4x Screw terminal block |
Ouputs power | 4x 50W @ 4 ohm (18V) |
Supply voltages | 12V DC Nominal 14.4V DC for rated power (50W) 18V DC Max |
Dimensions | 70x 40 x 75mm |
Mounting holes | 30 x 62 |
Weight | 94g |
Package | 1x Amplifier module 4.0 Class AB TDA7850 |
