This amplifier module features 6 channels and is based on 3 TPA3255 chips to deliver an output power of 6x260W at 4Ω or 6x150W at 6Ω. This module requires a power supply of 24-48V DC (sold separately) and integrates 3 12V power supply outputs for the fans, as well as an 8.5V auxiliary power supply output.
1 | Audio output terminal |
2 | Audio output terminal |
3 | Audio output terminal |
4 | Power input terminal |
5 | Audio output terminal |
6 | Audio output terminal |
7 | Audio output terminal |
8 | 12V power supply port for fan |
9 | 12V power supply port for fan |
10 | 12V power supply port for fan |
11 | 6x Unbalanced audio signal input |
12 | Auxiliary 8.5V power port |
Be careful not to confuse the input voltage of the power supply terminal block (circled in red in the photo) with the polarity of the audio outputs surrounding it.
Product type | Amplifier module |
Amplification type | Class D |
Amplification chips | 3x TPA3255 |
Channels | 6 |
Input | 1x 8-pin Molex (unbalanced input) |
Output | 6x Screw terminals |
Power output | 6x 260W @ 4Ω 1%THD 6x 315W @ 4Ω 10%THD 6x 150W @ 6Ω 1%THD 6x 185W @ 6Ω 10%THD |
Frequency response | 20Hz-20kHz |
Dynamic range | > 100dB |
Signal-to-noise ratio (SNR) | > 111dB |
Supply voltage | 24-48V DC (sold separately) |
Dimensions | 260 x 130 x 34mm |
Mounting holes | 117 x 241mm |
Weight | 720g |
Package | Sold by unit |
Input | Molex |
Output | Screw terminals |
Channel | 6 |
Class | Class D / T |
Amplifier chip | TPA3255 |
Power (W) | 260.0 |
