2.1 Amplifier Module WiFi DLNA Bluetooth 5.0 Tone Control 2x50W + 100W
The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the convenience of audio streaming. It supports WiFi, Bluetooth 5.0, DLNA, UPnP, AirPlay and Spotify Connect. The module's clever and smart design also ensures accurate and detailed sound reproduction.
The module also offers a physical connection with an Ethernet RJ45 input, a USB-A connector (USB Host), a 3.5mm jack and a Micro USB.
The amplifier embeds a series of 3 buttons. The first one will allow you to adjust the volume level, the two others will adjust the bass and treble according to your listening and your audio system.
Currently, it is difficult to find an amplifier that is both 2.1-channel and supports wireless transmission, especially WiFi, and is also in this price range. The Arylic Up2Stream Amp 2.1 fills this gap and does it brilliantly.
The AMP2.1 module has a filter function with a high pass filter on its stereo output / low pass filter on its mono output.
The default cutoff frequency is 110Hz and can be set from 50Hz to 200Hz by long pressing the Treble (30Hz increment) and Bass (30Hz decrement) buttons.
While the bass and treble levels can be adjusted via the buttons on the module or via a remote control (sold separately), free software is also provided. ACPWorkbench thus allows a more precise equalization thanks to its graphical interface.
The amplifier is compatible - via its mobile application 4Stream - with many streaming services. You can simply stream remotely from Spotify, Deezer, Qobuz, Tidal, Napster, Amazon Music, Pandora, iHeart Radio or web radios.
The Arylic Up2Stream Amp 2.1 allows you to easily and quickly set up an efficient multiroom system, directly controlled from your smartphone. Each module appears within the mobile application and can be controlled individually or synchronized.
The free 4Stream mobile application, available for both Android and iOS smartphones, will allow you to easily and remotely control all your Arylic Up2Stream Amp 2.1 modules.
Product type | Amplifier module |
Power | 2x50W @ 4Ω + 100W @ 2Ω, BTL, 24V 2x30W @ 8Ω + 75W @ 4Ω, BTL, 24V 2x22W @ 8Ω + 48W @ 4Ω, BTL, 19V 2x15W @ 8Ω + 30W @ 4Ω, BTL, 15V |
Inputs | 1x Jack 3.5mm 1x 4 Pins connector 1x Micro USB 1x Ethernet RJ45 10/100M 1x USB-A (USB Host) |
Output | 1x Connector for speakers and subwoofer (pins spacing : 5mm) |
Connectivity | WiFi (IEEE802.11 b/g/n 2.4G) Bluetooth 5.0 (SBC/AAC) DLNA UPnP AirPlay Spotify Connect QPlay |
Bluetooth transmission distance | 10m |
Supported streaming services | Spotify Deezer Qobuz Tidal Amazon Music Napster Webradios Pandora iHeart Radio ... |
Volume control | |
Tone control | Via buttons, remote control (sold separately) or ACPWorkbench software : Bass and Treble |
Frequency response | 20Hz - 20kHz |
THD | < 0.03% @ 1kHz / 1W / 24V / 4Ω |
Speakers impedance | 4-8Ω |
Supported file formats | FLAC, MP3, AAC, AAC+, ALAC, APE, WAV |
Supported sampling rates | PCM up to 24bit 192kHz |
Tension d'alimentation | 12-24V DC |
Dimensions | 124 x 100 x 25mm |
Package | 1x Arylic Up2Stream Amp 2.1 1x 6 Pins connector 1x WiFi antenna 3x Knob cover 1x Screwdriver |
Input | RJ45 |
Input | Bluetooth |
Input | WiFi |
Input | Jack 3.5mm |
Output | Speaker terminal |
Channel | 2.1 |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 100.0 |
Power (W) | 50.0 |
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bruno F.
Fabien F.
GEORGIOS N.
