ARYLIC UP2STREAM AMP MONO Amplifier Board WiFi Bluetooth 5.0 60W 4 Ohm
The Arylic Up2Stream AMP Mono is a small, powerful and versatile amplifier module offering advanced wireless connectivity. The amplifier stage of the module is capable of developing a power of 60W under 4Ω.
Reference : 14945
95,90 €tax incl.
79,92 € tax excl.
Shipping date: 17-04-2026.
Arylic Up2Stream AMP Mono Module Amplificateur WiFi Bluetooth 5.0 2x 60W 4 Ohm
POWERFUL STEREO SYSTEM
Two AMP Mono modules can be combined to form a powerful stereo system. The configuration is very simple and fast, in only 2 steps.
POLYVALENCE
Suitable for all situations and integrations, the AMP Mono integrates both a digital output (I2S) and an analog output (DAC).
EASY TO USE
The selection of the output mode, mono or stereo, is extremely easy, using jumpers.
Sound throughout the house
The AMP Mono can be paired with a stereo amplifier to create a 2.1 audio system, or multiple modules can be placed in different rooms to create a multi-room system.
Broad compatibility
The Arylic Up2Stream AMP Mono is compatible with many streaming services such as Spotify, Qobuz, Tidal, Deezer, Napster, iHeart Radio and web radio. It will also allow you to access music stored locally on your NAS or USB storage device.
Wireless Connectivity
Featuring full wireless connectivity, AMP Mono allows you to stream your music over WiFi or Bluetooth 5.0, and supports DLNA, UPnP, AirPlay and Spotify Connect.
USB DAC & Custom Settings
The AMP Mono can be connected to your PC via its Micro USB connector to function as an external DAC. It is also possible to use ACPWorkbench to customize the frequency and equalization settings.
4Stream App
The Arylic 4Stream application, available on iOS and Android, will allow you to control your AMP Mono modules simply and remotely. It will also inform you, via a notification, of the availability of a firmware update.
Application 4Stream Android Play Store Application 4Stream iOS App Store
Product typeAmplifier board
ChannelMono (1)
Power output (Mono)100W @ 2Ω BTL, 24V
60W @ 4Ω BTL, 21V
30W @ 8Ω BTL, 15V
Power output (Stereo)2x 50W @ 4Ω BTL, 21V
2x 30W @ 8Ω BTL, 24V
2x 15W @ 8Ω BTL, 15V
Inputs1x Jack 3.5mm
1x 4 pins connector
1x Micro USB
1x Ethernet RJ45 Single 10/100M
Outputs1x Speaker connector (pin spacing : 5mm)
1x 4 pins connector (stereo)
1x 2 pins connector (mono)
1x SPDIF Output
Wireless connectivityWiFi IEEE802.11 b/g/n 2.4G
Bluetooth 5.0 (SBS/AAC)
Transmission à distance Bluetooth10m
THD0.03% @ 1kHz, 2x50W, 24V, 4Ω
Speaker impedance4-8Ω
Supported file formatsFLAC, MP3, AAC, AAC+, ALAC, APE, WAV
Supported sampling ratesPCM up to 24bit 192kHz
Supported transmission protocolsAirPlay, DLNA, UPnP, Spotify Connect, QPlay
Power supply12-24VDC via Jack DC 5.5/2.1mm / 2 pins connector
Dimensions110 x 80 x 22mm
Package1x Arylic Up2Stream Amp Mono
1x Screwdriver
1x 4 pins analog connector
2x Antennas
InputRJ45
InputJack 3.5mm
OutputI2S
OutputSPDIF
Channel1 (Mono)
Amplifier chipN/A
Power (W)60.0
Super produit
Ma vieille TSF s’est transformée en enceinte connectée ; tout marche nickel !!
This review has been posted for ARYLIC UP2STREAM AMP MONO Amplifier Board WiFi Bluetooth 5.0 60W 4 Ohm
The Arylic Up2Stream AMP Mono is a small, powerful and versatile amplifier module offering advanced wireless connectivity. The amplifier stage of...
