CL-500A Amplifier Board TDA7498E Bluetooth 5.0 WiFi AirPlay2 2x100W 4 Ohm
The CL-500A is a particularly complete and powerful Class D amplifier module. Based on a TDA7498E amplifier chip, it is capable of developing no less than 2x100W under 4 Ohm with a high efficiency, while offering a clear and dynamic restitution.
Reference : 15398
109,00 €tax incl.
90,83 € tax excl.
CL-500A
Module Amplificateur Class D TDA7498E WiFi AirPlay2 DLNA Bluetooth 5.0 2x100W 4 Ohm
The CL-500A is a particularly complete and powerful Class D amplifier module. Based on a TDA7498E amplifier chip, it is capable of developing no less than 2x100W under 4 Ohm with a high efficiency, while offering a clear and dynamic restitution. With an extended connectivity, it will allow you to broadcast your music remotely via WiFi or Bluetooth 5.0 from any other connected device. There are also inputs for Ethernet (RJ45) for a wired network connection, a stereo RCA, Optical Toslink and a USB-A connector for connecting a storage device. On the output side, the CL-500A has a speaker output but also an RCA output and a Toslink Optical output. The module is also compatible with the DLNA and AirPlay2 transmission protocols. The CL-500A comes with an IR remote control that will allow you to control the playback from your sofa.
Product typeAmplifier board
Amplification typeClass D
Amplifier chipTDA7498E
InputsWiFi 2.4/5Ghz
1x Ethernet RJ45
Bluetooth 5.0
1x Stereo RCA
1x USB-A
1x Optical Toslink
OutputsSpeaker terminals
1x Stereo RCA
1x Optical Toslink
WiFi ProtocolsIEEE 802.11 a/b/g/n/ac 1x1 dual band 2.4/5GHz
Bluetooth version5.0, compatible EDR / BLE
Output power2x100W @ 4Ω
THD+N0.05%
SNR105dB
Supported formatsMP3, AAC, FLAC, ALAC, WMA, APE, WAV, OGG
Supported transmission protocolsAirPlay2, DLNA, QQ Music Qplay
Dimensions107 x 136 x 29mm
Supply voltage24VDC 6A / 28VDC 5A / 32VDC 5A (power supply not included)
Weight184.5g
Package1x Module CL-500A
1x IR Remote control
InputWiFi
InputRJ45
OutputOptical Toslink
OutputSpeaker terminal
Channel2 (Stereo)
Power (W)100.0
The CL-500A is a particularly complete and powerful Class D amplifier module. Based on a TDA7498E amplifier chip, it is capable of developing no...
