Class D Amplifier Module Infineon MA12070 Bluetooth 5.0 2x55W 4 Ohm
This Class D amplifier module uses an Infineon MA12070 chip allowing it to deliver 2x55W of power at 4Ω with great efficiency while providing accurate and consistent sound reproduction.
Reference : 17376
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 19-05-2026.
Amplifier Board
Class D Infineon MA12070 Bluetooth 5.0 2x55W 4Ω
Module amplificateur Class D Infineon MA12070 Bluetooth 5.0 2x55W 4Ω
This Class D amplifier module uses an Infineon MA12070 chip allowing it to deliver 2x55W of power at 4Ω with great efficiency while providing accurate and consistent sound reproduction. A built-in volume knob allows for easy sound level changes. Regarding the inputs, the amplifier offers Jack 3.5mm as well as a Bluetooth receiver allowing to broadcast its music remotely, from a smartphone or a tablet for example. The output to speakers is done simply using screw terminals.
The module is in Bluetooth mode by default. If you wish to change the source, you must insert a 3.5mm jack into the AUX input.
Product typeAmplifier module
Amplification typeClass D
InputsBluetooth
1* Jack 3.5mm
OutputSpeaker screw terminals
Output power2*55W @ 4Ω
Efficiency90%
Supply voltage18-24VDC via Jack DC 5.5/2.1mm (power supply sold separately)
Dimensions67*82*21mm
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipInfineon MA12070
Power (W)55.0
This Class D amplifier module uses an Infineon MA12070 chip allowing it to deliver 2x55W of power at 4Ω with great efficiency while...
