HYPEX FUSIONAMP FA251 Plate NCore Amplifier 1x250W DSP ADAU1450 DAC AK4454
The Hypex FusionAMP FA251 amplifier will allow you to design a one-way active speaker or a sub active subwoofer. This is based on an NCore module capable of developing 250W RMS.
By buying this product you get 39 loyalty points
Reference : 14542
399,00 €tax incl.
332,50 € tax excl.
Shipping date: 13-05-2025.
Plate NCore Amplifier 250W DSP ADAU1450 DAC AK4454
Hypex FusionAMP FA253 Amplificateur NCore Plaque 2x250W + 100W DSP ADAU1450 DCC AK4454 192kHz
The Hypex FusionAMP FA251 plate amplifier can be used to design a one-way active speaker. It is based on a NCore amplifier module capable of delivering 250W RMS. This high power allows it to drive speakers that need a large energy reserve to reveal their potential.
Connectivity & other features
On the connector side, the FA251 offers a balanced analog input and output in XLR 3-pin format and an unbalanced RCA Stereo input. The XLR output is directly connected to the XLR input and therefore allows you to create a chain with multiples FusionAMPs, the maximum number of modules being limited by the capabilities of your source. Moreover, the module has a High Level input for analog amplified signals.
This FusionAMP FA251 includes a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. The latter offers many possibilities to adapt your amplifier to your needs, such as creating custom filters.
When associated to a HYPEX FUSION REMOTE KIT FA251 amplifier module can receive commands from an infrared remote. This module also has a remote output to chain remote commands with other Hypex Fusionamp modules, allowing to control a whole complex installation from a single central remote.
The front of the amplifier displays a series of 4 status LEDs. The first one is used to warn of a malfunction or when a limit is reached, in order not to damage the equipment.
  • Fixed green : Amplifier power on
  • Blinking green : IR signal received
  • Green / red blinking : Clipping signal
  • Slow green blinking : Mute mode (output not workink)
  • Fixed red : DC Error/ Fatal error, amplifier shutdown
  • Blinking one time per second : High temperature, limited output
  • blinking two time per second : Over temperature, output not working
The next 3 LEDs, green, simply display the selected custom profile and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will flash slowly.
1Balanced analog XLR input / output
2Single-ended RCA input
3Mini-USB connector for configuration
4Status LED
5High level input
6Remote input / output
7Gain control
Operating diagram
Note: In order to protect your speakers, the DSP does not have a filter pre-configured by the manufacturer. A filter must therefore be configured and injected using Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
Product typePlate amplifier
Power250W
Inputs1x Balanced 3 poles XLR
1x Single-ended RCA
1x High level (cable is included)
1x Mini-USB (DSP programmation only, no audio signal)
1x Remote (DSP commands only, no audio signal)
Outputs1x Balanced 3 poles XLR (direct output)
DSPADAU1450
DACAK4454
ADCAK5554
SNR AD/DA-109dB
SNR DA-111dB
THD+N AD/DA-100dB @ -1dBFS
THD+N DA-102.5dB @ -1dBFS
Dimensions360 x 135mm
Weight1145g
Dimensions
A360mm
B135mm
C55mm
D336mm
E111mm
InputXLR
Channel1 (Mono)
Amplifier chipHypex Ncore
Power (W)250.0
Pour piloter un caisson
L'ampli fonctionne très bien. Parfait pour un caisson. Tout est parfait, en revanche, pour initiés. L'interface graphique du logiciel permettant de régler le DSP de l'ampli est très complète et efficace....mais on peut pas vraiment dire que l'ergonomie soit son point fort! Avec quelques connaissances en audio ou de l'aisance à fouiller sur les forums spécialisés, on s'en sort, rien d'infaisable.
This review has been posted for HYPEX FUSIONAMP FA251 Plate NCore Amplifier 1x250W DSP ADAU1450 DAC AK4454
The Hypex FusionAMP FA251 amplifier will allow you to design a one-way active speaker or a sub active subwoofer. This is based on an NCore module...
