HYPEX FUSIONAMP FA501 Plate NCore Amplifier 1x500W DSP ADAU1450 DAC AK4454 192kHz
The Hypex FusionAMP FA501 plate amplifier can be used to design a subwoofer or speaker as an active channel. It is based on an NCore module capable of developing no less than 500W RMS. This high power allows it to accompany speakers that need a large energy reserve to reveal their potential.
4.0 / 5
Reference : 13529
499,00 €tax incl.
415,83 € tax excl.
Shipping date: 07-04-2026.
Hypex FusionAMP FA501 Amplificateur NCore Plaque 1x500W DSP ADAU1450 DCC AK4454 192kHz
Connectivity and other features
On the connector side, the FA501 offers a balanced analog input and output in XLR 3-pin format and an unbalanced RCA Stereo input. The XLR output is directly connected to the XLR input and therefore allows you to create a chain with several FusionAMPs, the maximum number of modules being limited by the capacities of your source. the amplifier also has a high level input so that you can connect your previous amplifier to it if it does not have a pre-out output. Finally, an I/O connector in RCA format allows the module to be connected to the remote control of another FusionAMP amplifier module (remote control and receiver module sold separately).
This FusionAMP FA501 integrates a DSP. A USB connector allows you to configure your amplifier via the software specially developed by Hypex. The latter offers many possibilities to adapt your amplifier to your needs, such as creating custom filters.
The front of the amplifier displays a series of 4 status LEDs. The first one is used to warn of a malfunction or when a limit is reached, in order not to damage the equipment.
  • Fixed green : Amplifier ON
  • Blinking green : IR signal received
  • Green / Red blinking : Clipping signal
  • Slow green blinking : Mute mode
  • Fixed red : DC / Fatal error, amplifier Power OFF
  • Red blinking 1 time per second : High temperature, limited output
  • Red blinking 2 time per seconde : Over temperature, output muted
The next 3 LEDs, green, simply display the selected custom profile and therefore in use. To change the profile, simply press the Select button. If the amplifier is in mute mode, then the LED of the selected profile will flash slowly.
Finally, a potentiometer placed under the LEDs will allow you to control the gain level of your amplifier very easily. By default, this gain can be adjusted by 12dB in each direction.
1Balanced XLR Input / Output
2Single-Ended RCA Input
3Mini-USB connector for configuration
4State LED
5High level input
6Input / Output Remote Control
7Gain adjustment
Operating diagram
Note: In order to protect your speakers, the DSP does not have a filter pre-configured by the manufacturer. A filter must therefore be configured and injected using Hypex Filter Design (HFD) software for the FusionAMP to provide an output signal.
Product typePlate amplifier
Power1x500W
Inputs1x Balanced 3 poles XLR
1x Single-Ended Stereo RCA
1x High level 4 poles input
Outputs1x Balanced 3 poles XLR (Direct output)
I/O connector for remote controlRemote control and IR receiver sold separately
DSPADAU1450
DACAK4454
ADCAK5554
SRCSRC4382 - Max sample rate : 192kHz
SNR AD/DA-109dB
SNR DA-111dB
THD+N AD/DA-100dB @ -1dBFS
THD+N DA-102.5dB @ -1dBFS
Dimensions135 x 280mm
Weight925g
ColorNoir
Package1x FusionAMP FA501
1x Speaker cables
1x High Level cable
Dimensions
A280mm
B135mm
C55mm
D256mm
E111mm
InputXLR
Channel1 (Mono)
Amplifier chipHypex Ncore
Power (W)500.0
Bon ampli et DSP paramétrable
J'ai acheté cet ampli pour alimenter mon subwoofer JMLab SW900 car l'ampli d'origine tombait régulièrement en panne du fait des vibrations (faux contacts sur le circuit imprimé).
J'ai donc sorti l'ampli pour qu'il ne soit plus soumis aux vibrations et cet ampli fait bien le job. La paramètrage du DSP se fait avec un micro et une carte son calibrés et les logiciels REW, HFD et rePhase.
Le processus de paramètrage se fait sans souci une fois qu'on a compris la méthode et maitrisé les logiciels. J'ai mis plusieurs jours avant d'aboutir au résultat final.
Cette petite critique n'est pas spécifique de Hypex car tous les DSP sont comme cela. On pourrait réver d'un logiciel intégré un peu comme Audissey dans les amplis Home-cinema qui fait à la fois la mesure, le calcul et l'implémentation...
Ceci étant je ne met pas 5 étoiles car le résultat acoustique s'est certes amélioré par rapport à l'ampli d'origine sous l'angle courbe de réponse mais s'est un peu dégradé en réponse impulsionnelle.
Cela est certainement dû à l'empilement des traitements avec un convertisseur ADC puis les filtres DSP puis le convertisseur DAC.
Néanmoins content de mon achat
This review has been posted for HYPEX FUSIONAMP FA501 Plate NCore Amplifier 1x500W DSP ADAU1450 DAC AK4454 192kHz
The Hypex FusionAMP FA501 plate amplifier can be used to design a subwoofer or speaker as an active channel. It is based on an NCore module capable...
