HYPEX FUSIONAMP FA502 NCore Amplifier Module BTL 2x500W 4 Ohm
The Hypex FusionAmp FA502 is an amplifier module with integrated DSP, ideal as a design basis for an active 2-way speaker or active subwoofer. Due to the integration of SMPS power supply, DSP and Class D Ncore amplifier, the FusionAmp is one of the best solutions available for active speaker design.
Reference : 15824
699,00 €tax incl.
582,50 € tax excl.
Shipping date: 16-04-2026.
Amplifier module Ncore BTL 2x500W 4Ω
Hypex FusionAmp FA502 Module Amplificateur Ncore BTL 2x500W 4Ω
The Hypex FusionAmp FA502 is an amplifier module with integrated DSP, ideal as a design basis for an active 2-way speaker or active subwoofer. Due to the integration of SMPS power supply, DSP and Class D Ncore amplifier, the FusionAmp is one of the best solutions available for active speaker design. The on-board DSP provides excellent audio signal processing capability. The Ncore technology allows it to achieve a very low level of distortion (THD and IMD) over the entire power range.
The FA502 uses two 500W Ncore amplifiers, which can also be bridged to form a single 1000W amplifier. Numerous input options ensure compatibility with most source devices. Hypex also provides its HFD (Hypex Filter Design) software, allowing the configuration of filters for the FusionAmp.
In order to protect your speakers, the DSP does not include a basic crossover. A crossover must be configured and uploaded via the Hypex Filter Design software, before the FusionAmp can produce an output signal.
Product typeAmplifier module
Amplification typeClass D
AmplifierNcore
Output power2x500W RMS @ 4Ω
2x350W @ 8Ω
2x450W @ 2Ω
BTL Output power1x1000W RMS @ 4Ω
1x1200W @ 8Ω
Minimum load2Ω
Inputs1x Balanced XLR
1x Single-ended RCA
1x AES
1x Coaxial
1x Optical Toslink
1x Mini USB configuration interface
Pass-Through outputs1x Balanced XLR
1x AES
1x Coaxial
SNR124dB
Distortion0.0018% THD+N (10Hz-20kHz @ 0.5 x output power)
Efficiency92% @ max power
Frequency response10Hz-50kHz
Input impedance54kΩ @ Single-ended RCA
44kΩ @ Balanced XLR DM
2.2mΩ @ Balanced XLR CM
Max sampling rates192kHz
Optical: 96kHz
BTL Compatibility
Input selection
Auto shutdown
Signal detection
DSP
DAC
Equalizers
Phase control
Crossover frequency control
Presets
Supply voltage200-240VAC ±10%
Dimensions380 x 150 x 90mm
Cutout dimensions356 x 126mm
Weight2.88kg
Package1x Hypex FusionAmp FA502
Spaeker connection cables
InputAES/EBU
InputXLR
OutputAES/EBU
OutputCoaxial SPDIF
Channel1 (Mono)
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)1000.0
Power (W)500.0
The Hypex FusionAmp FA502 is an amplifier module with integrated DSP, ideal as a design basis for an active 2-way speaker or active subwoofer. Due...
